Switching preview from image info to picture?!
showmeinfinity
Post by showmeinfinity »
I cleverly clicked on the tiny icon at the top right of the preview pane and it switched to the image information tabs. But I can't for the life of me figure out how to switch it back to showing a preview image! I've looked everywhere at the settings and interface. Please help, thanks!
Erixx haxx
Re: Switching preview from image info to picture?!
Post by Erixx haxx »
Did you check under:
"View: Info pane:
You might Check or uncheck "show as menu" and check or uncheck "preview".
these options are above the main toolbar. File.. Edit.. View
showmeinfinity
Oh that worked, thank you!!! I had to also check "preview as tab".
And... how can I get rid of the stars at the bottom of the preview pane?
Erixx haxx
Settings -
Browser -
Uncheck: Show ratings..
showmeinfinity
Thansk!!!
