[OK] RC1: Startup Directory - Current still doesn't work
This is an old bug but I thought I'd mention it. Options - Browser - Startup Directory - Current doesn't work but behaves as Last used instead.
Roman
Roman
Re: Startup Directory - Current still doesn't work
If you start xnview.exe? I can't reproduce it, could you explain more?Hacker wrote:This is an old bug but I thought I'd mention it. Options - Browser - Startup Directory - Current doesn't work but behaves as Last used instead.
Roman
I have "c:\Programy\XnView\xnview.exe" as one of the icons in Total Commander's Button Bar. The Start Path for XnView's entry is empty. Now, when I click that icon XnView is started and I always land in the last used directory, even though I have defined I want to land in the current dir.
Example:
Use XnView, go to c:\alpha\, exit XnView.
In TC, navigate to c:\beta\.
Click XnView's icon. XnView starts in c:\alpha\ instead of c:\beta\.
The current workaround is to add "%P" (current path) to the Parameters field in TC's Button Bar for XnView.
Roman
Example:
Roman
It has its own image viewer and "thumbnail viewer. I want to switch to another (free) file manager too.Hacker wrote:Dreamer,Use TC.I'm using Servant Salamander so I can't help you.
No, seriously, Servant Salamander does have an equivalent of the TC Button Bar, doesn't it? Does it work when calling XnView from there?
Roman
But I'll try to check later, too busy now
I use xplorer2 lite (freeware):
http://zabkat.com/x2lite.htm
Ok, i'll change it in RC2, please test it with RC2...Hacker wrote:This is an old bug but I thought I'd mention it. Options - Browser - Startup Directory - Current doesn't work but behaves as Last used instead.
OL
