Maybe in next releases ..."Keyword" = "Hill"
AND
"Keyword" = "holidays"
AND
"author" IS NOT "John Miller"
Peter
AND
AND
+1 I supportPeter2 wrote:The integrated search-function can only search for one IPTC-entry. It would be fine if there would be an extended search (like in Total Commander):Maybe in next releases ..."Keyword" = "Hill"
AND
AND
Peter
You can use 'Folder', 'Category' and any information field (Image and File characteristics, EXIF, IPTC, etc...) to build Searches [+using the logical: AND, OR, NOT, and () ]
This was supposed to be used also with hierachical IPTC categories.You could directly select multiple Categories, Folders, Searches and Information (with Ctrl & shift keys) and see the syntax of the resulting search in the 'Preview/Search' area. You could also add conditions just by dragging and dropping them directly in the window. You would be able to edit directly the syntax in the 'Preview/Search' area: change AND/OR, add ()/NOT, move objects, change conditions (=, <, > for Information fields), change inclusion (Folder/Category only or include sub-levels), etc...
Yes, it's probably that why ...But it would require quite a lot of work... & time...
Any change for an implementation?Peter2 wrote:The integrated search-function can only search for one IPTC-entry. It would be fine if there would be an extended search (like in Total Commander):
AND
AND
