Mouse detection on thumbnails shifted to the right
Olivier_G
Post by Olivier_G »
In the Browser filelist area with 'View as Thumbnail', if you click near the left edge of a thumbnail (within 8 pixels of edge), the thumbnail on the left will be selected instead of the one you are trying to select. It applies also for tooltip edge detection.
(+both of them should not be selected, as thumbnail selected as its edge detection +8 pixels on both sides. Strange! :| )
V1.90 B1
Olivier
Re: B1: mouse detection on thumbnails shifted to the right
Olivier_G wrote:In the Browser filelist area with 'View as Thumbnail', if you click near the left edge of a thumbnail (within 8 pixels of edge), the thumbnail on the left will be selected instead of the one you are trying to select. It applies also for tooltip edge detection.
On Xp?
Olivier_G
Post by Olivier_G »
xnview wrote:On Xp?
Yes: XP SP2.
(side-note: I just updated my signature to show more informative info during Beta test drive. Could be more convenient)
Olivier
Troken
Post by Troken »
Confirmed. But its really on the very edge, less than 8 px I think.
marsh
Post by marsh »
Confirmed on Win2k.
Ok, i have the problem, :-(( Rhhhh windows....
Perhaps this problem is related with "B1: Tags are difficult to set".
Pixels…
:) Hello !
• With regard to an image I blown-up before to spot at width, it seems that the error zone is 5 pixels from left…
:mrgreen: KR
helmut wrote:Perhaps this problem is related with "B1: Tags are difficult to set".
Yes, it's the same thing, windows API seems to use a 6/8 pixels border around the icon to make the selection :-(
Olivier_G
Post by Olivier_G »
There is still an issue about shifted selection with Beta 2 (also reported here).
Actually, this bug was already in previous versions (I confirm in 1.82.4). Not a major one, though... :|
Olivier
