XnView Shell Extension (Support & Development)
How to use XnView. Post your question or ask for help, here.
Moderators: Olivier_G, Dreamer, XnTriq, helmut, xnview
Postby xnview » Wed Oct 13, 2004 11:35 am
XnView shell extension allows for viewing a thumbnail of the selected image in the context menu of MS Explorer.
XnView shell extension 2.0 in action:
The XnView Shell extension can be downloaded on the XnView Download page.
Direct link is http://download.xnview.com/XnShellEx.exe
Re: XnView shell extension
Postby xnview » Thu Oct 14, 2004 11:50 am
V1.2 available
4 languages, thumbnail size
Postby maadjordan » Wed Oct 27, 2004 8:59 pm
if shell would support languages.. why don't you use Xnview one .. so no need to include or make a new lang file..
XnView Arabic Support
maadjordan
XnShellEx.exe v. 1.2 Error at installation
Postby Clo » Wed Oct 27, 2004 11:27 pm
:) Hello Pierre !
¤ I just attempted to install this program. I got this error-message
* Does it work under Win 98SE ? I didn't see it doesn't work with this OS in the start-post…
:mrgreen: Kind regards,
Re: XnShellEx.exe v. 1.2 Error at installation
Postby ckit » Thu Oct 28, 2004 12:46 am
Clo wrote::) Hello Pierre !
Hmm, thats strange I didn't have any problems installing XnView ShellEx v1.2.
However my XnView is installed in C:\Program Files\XnView not sure if it makes a difference or not.
XnView 1.97 and XnViewMP beta 0.21 on Windows 7 Pro x64
AnVir Task Manager Pro. Burning Studio, Avira Premium, CCleaner, CintaNotes, Executor, PhotoFiltre Studio X, Process Lasso Pro, xplorer² Pro, WinRAR
ckit
Postby xnview » Thu Oct 28, 2004 7:15 am
Strange, someone else with the same problem on Win98SE?
What DLL ?
Postby Clo » Thu Oct 28, 2004 12:15 pm
:) Hi again Pierre !
- The snag is that the error-message doesn't tell WHAT other needed file is missing or not found WHERE…
- I thought that under Win 98 SE, the System-dir is C:\windows\System, while it's C:\windows\System32 in NT-based OSs.
- Moreover, the variable for CSIDL_SYSTEM is not supported by Win 98:
- On this pic - a part of a Registry variable-strings viewer result-window-, it's obvious that %SYSTEM% or so can't work; it could be possible to force Win to set it, but this needs a Shell32.dll version 5.0, while the newest supported by Win 98 SE is mine : v. 4.72.3612.1700, already newer than the original one (patch…)
•  Hence, whether the issue is located around this, the full paths could solve the problem…
:mrgreen: Kind regards, Claude
Postby Guest » Mon Nov 22, 2004 4:40 am
A suggestion:
If it's not too hard and/or cumbersome to code, how about a way for a user to limit the thumbnail, such as no thumbnail preview for images over 2 megs in size?
This extension is almost perfect for a not so computer savvy friend running '98 with only 64megs of ram.
Postby ckit » Mon Nov 22, 2004 5:09 am
ckit
supported formats
Postby dani » Fri Nov 26, 2004 11:35 pm
What image formats are supported on the thumbnail view?
dani
Re: supported formats
Postby xnview » Sat Nov 27, 2004 8:56 am
dani wrote:What image formats are supported on the thumbnail view?
The most used, not all
Postby aardvarko » Sat Jan 29, 2005 10:57 pm
Shell extension dies horribly when corrupted/malformed JPEGs are right-clicked, which makes it a little annoying to delete them.
aardvarko
Postby xnview » Mon Jan 31, 2005 8:25 am
aardvarko wrote:Shell extension dies horribly when corrupted/malformed JPEGs are right-clicked, which makes it a little annoying to delete them.
Could you send a sample, please?
How about a submenu?
Postby notnoisy » Wed Mar 09, 2005 11:01 am
I would prefer to view the thumbnail in a submenu. Is it possible to get this as an option?
My explorer context-menu is becoming a bit long :)
notnoisy
Re: How about a submenu?
Postby mika99 » Sun May 15, 2005 7:20 pm
If you right click on a Nikon D70 NEF raw file the shell extension locks the explorer for some seconds an then crashes (the explorer).
Is it as a workaround possible to exclude this file type?
mika99
Next
Return to General Support
Who is online
Users browsing this forum: No registered users and 3 guests
