Thanks for this really great freeware image viewer!
I've got some issues with the slide show feature under Win 98 SE on my PIII-550MHz:
In fullscreen view, the size of large images is always reduced using the low quality zoom even though I enabled the high quality zoom in the options dialog.
Also it would be nice if the "read one image ahead" option did have an effect on slide shows as well...
Opening a previously saved slide show always resets the "show information" option in the "slide show" options dialog. Even if I turned that option off right before saving the slide show it is turned on after loading the show. But I'd rather show the images without the filename displayed.
Take care and keep up the good work!
Slide Show Problems with 1.74
Re: Slide Show Problems with 1.74
ThanksMiniMe wrote:Thanks for this really great freeware image viewer!
OkIn fullscreen view, the size of large images is always reduced using the low quality zoom even though I enabled the high quality zoom in the options dialog.
I'll checkOpening a previously saved slide show always resets the "show information" option in the "slide show" options dialog. Even if I turned that option off right before saving the slide show it is turned on after loading the show. But I'd rather show the images without the filename displayed.
