I have installed XnView ver. 1.90.2 (with Nconvert 1.77) on WinXP Home SP2. I started to edit a JPG picture: a rectangular area was selected and tried to copy to MS Word 8.0.
I used Ctrl-C in XnView and Ctrl-V in Word, but instead of selected area  only the tab title appears in Word document. I tried Ctrl-X and Ctrl-V instead, this worked perfectly.
It seems to have  problem with copying to clipboard.
						Problem with copying selected part of picture
Re: Problem with copying selected part of picture
You use Ctrl+C in view mode or browser?piliktal wrote:I have installed XnView ver. 1.90.2 (with Nconvert 1.77) on WinXP Home SP2. I started to edit a JPG picture: a rectangular area was selected and tried to copy to MS Word 8.0.
Now XnView copy in the clipboard pathname AND image data, word seems always copy the text clipboard
				piliktal
Exactly I closed the browser, took a scren-capture, zoom it a little, made the selection and hit Ctrl-C (or select Edit - Copy from menu).
Ctrl-X (or Edit - Cut) works!
I don't believe that Word knows how the clipboard-content was made.
In ver. 1.90 all of these was OK.
In Word, you must choose "special paste" or something like that...piliktal wrote:Exactly I closed the browser, took a scren-capture, zoom it a little, made the selection and hit Ctrl-C (or select Edit - Copy from menu).
				piliktal
Yes, you are right, of course!
After Ctrl-C, the selected part of picture AND the path/tab title as text are copied to the clipboard. In Word the Ctrl-V get the TEXT from clipboard. In "special paste" it is possible to select what will be copied from clipboard: TEXT OR PICTURE.
After Ctrl-X ONLY the selected part of picture is copied to clipboard, so word gets it (no anything else in the clipboard).
Thank you very much for information!
Best regards: PiliktaL
