First great program, I always used it since the day I tried it. One of my top favorite windows app (Still did not install it on ubuntu).
Knowing that I use it to read mangas in fullscreen with "Auto image size" set to "No fit", I ticked "Reset X/Y" to be sure that each time I browse to the next page, it scrolls up automatically to the top of the picture.
However, the option is only present in "View" mode, and setting "Auto image size" to "Fit image to window, large only" makes the option not available.
The problem is that is also affect the fullscreen behavior, since there is a "Auto image size" setting for each normal windowed view and fullscreen, knowing that I'm using "Fit image to window, large only" in windowed and "No fit" in fullscreen, the unavailable "Reset X/Y" setting from Windowed View mode is just simply turned off.
SO HERE IS MY QUESTION (finally) :
Isn't it possible to add a fullscreen specific "Reset X/Y" setting ?[/img]
