I've installed xnview on my windows x64 and everything works fine,
but when I try the shell ext for 64bits I have a problem at the end of the install process, here is the screenshot:
I hope it can help you in debugging.
regards.
tmaes
Try by unchecking 'XnView shell extension'tmaes wrote:Hi,
regsvr32 "c:\Program Files (x86)\2D\XnView\ShellEx\XnViewShellExt.dll"
