Anyway to view an image starting from the top, not middle?
nintendomaniac64
Post by nintendomaniac64 »
When an image's height is taller than the screen's height, it seems to default to viewing the the middle of the image. Is there anyway to make it view the top?
Also, if the image is also wider than your screen, is there anyway to make the viewer start from the left or the right side?
As a pretty avid manga reader, having to constantly scroll up to the top of a page is quite a pain :P Being able to view from the right would just be a bonus, but useful non-the-less.
Re: Anyway to view an image starting from the top, not middl
nintendomaniac64 wrote:When an image's height is taller than the screen's height, it seems to default to viewing the the middle of the image. Is there anyway to make it view the top?
Do you have enabled option/View/Reset X/Y?
Alan
Post by Alan »
Cannot find Reset X/Y in Tools/Options/View/.
Am I missing a plug-in or something?
Drahken
Post by Drahken »
Alan
Post by Alan »
Thanks. It was greyed-out because I had not set the Auto Image Size to 'No Fit'.
