Problem sorting by date
Peter A
Post by Peter A »
Sorting by "Date" or by "Exif-date" results in sorting by "Date modified", instead of sorting by "Date taken" or "Exif-date" resp.
(XnView 1.91 on Windows XP)
Re: Problem sorting by date
Peter A wrote:Sorting by "Date" or by "Exif-date" results in sorting by "Date modified", instead of sorting by "Date taken" or "Exif-date" resp.
I have no problem. Currently Exif-date sort by EXIF date modified...
Peter A
Post by Peter A »
Hello Pierre,
Thanks for responding.
I have taken a closer look and first set the language from Dutch to English to be sure we talk about the same items.
You are right (of course) sorting by Exif date results in sorting on exif "Date modified". I thought it would result in sorting on exif "Date taken", to be able to sort on the original date.
Is it possible to change this or to add sorting on exif ""Date taken" as after editing a foto with PSP XI the exif "Date modified" is changed and sorting goes wrong?
Peter
Peter A wrote:Hello Pierre,
Peter
The 1.91 will use the EXIF date taken
Peter A
Post by Peter A »
Peter
Thanks very much.
(By the way, do you mean the next version, as 1.91 is already available?)
Peter
Peter
Thanks very much.
Peter
Yes :-) the 1.91.1
