interface small bug - background in folder tree
dgiglio
Post by dgiglio »
I've found in
options - browser - folder tree tab
that there is no option for the background in the folder tree. there only is the text "Background color" but no button or sample color.
vers 1.91.1
xp SP2
thanks (great program)
Re: interface small bug - background in folder tree
dgiglio wrote:I've found in
vers 1.91.1
xp SP2
Right, it's an error. There is only a field in .ini
herr_k.
Post by herr_k. »
xnview wrote: There is only a field in .ini
so is it the "BackListColor" in .ini?
because if i change it, the background of the folder tree still remains white..
oops66
Post by oops66 »
No it's for black color:
TreeBackColor=0
or else xxxxxxx
TreeBackColor=2266269
herr_k.
Post by herr_k. »
hm,doesnt work.
btw, i am using the latest xn 1.91.3..
oops66
Post by oops66 »
Try again .... LOL
1-) You have to first quit xnview.
2-) Then change the xnview.ini and save.
(Do not save ini before exit xnview.)
[Browser]
TreeBackColor=0
TreeFontColor=6266269
TreeFontHiColor=99999999
For folder tree
http://newsgroup.xnview.com/viewtopic.php?t=13204
herr_k.
Post by herr_k. »
ah, you forgot to mention that it has to be under [browser].
if you just put it at the end, it doesnt work.
how can i figure out the color codes?
Headache---
—> herr_k.
• Hello !
…how can i figure out the color codes?
- The answer is in THIS MESSAGE
- The handier decimal code RRR GGG BBB might be supported in the next version,
according to the Pierre's statement in the French forum yesterday…
- It's already supported for the entries about the colours per file type and their backgrounds.
:mrgreen: VG
oops66
Post by oops66 »
like Here
exemple in Google:
http://www.docmemo.com/internetwebmaste ... uleurs.php
Code décimal: Rouge :xxx Vert : xxx Bleu : xxx
or with tool like:
FastStone Capture - screen color picker etc....
herr_k.
Post by herr_k. »
thanks guys, worked!
i would also prefer r g b though.
