Bug in Buttonbar
Gast
Bug in Buttonbar
Post by Gast »
Sorry bad english..
right click of Button in Buttonbar + left click same time with the right mouse button -> Program does not react any longer to menu or Button klicks.
mfg Henry
Re: Bug in Buttonbar
Gast wrote:Sorry bad english..
I can't reproduce this bug, on which OS?
Which XnView version do you use?
Perhaps this is the problem you experience:
There had been a problem in XnView version before 1.91, see topics "XnView is blocked" and "Lock-up when using toolbar". This problem has been fixed in XnView version 1.91.
Same bug
—> helmut
• Hi !
• I tested again now in 1.91.1, and obviously it's the same bug like the one you quote…
- It was fixed up, though, I don't know why it came back…
:mrgreen: G.
Re: Same bug
Clo wrote:—> helmut
• Hi !
You have this bug again in 1.91.1???
Alas
:arrow: Pierre
:) Again…
• Yes, I've it again. If you press both R & LMB on an icon, all freezes.
- Impossible to close from the Win [×] button.
- However, when other apps. are open, switching to any one >> back to XnView via Alt+Tab unlocks the close button…
:mrgreen: KR
Re: Alas
Clo wrote: • Yes, I've it again. If you press both R & LMB on an icon, all freezes.
Really strange, i have not changed this code between 1.91 & 1.91.1
Os is…
:arrow: Pierre
:) Hello !
• It occurs with Win XP-Pro SP1 here…
:mrgreen: KR
Gast
Sorry forgotten
Post by Gast »
OS: WinXP Prof SP2 + All Hotfixe
PC: Pentium E6300 + Geforce7100
I've just tested with XnView 1.91 on Windows XP SP2 and yes, the problem also occurs. :-|
helmut wrote:I've just tested with XnView 1.91 on Windows XP SP2 and yes, the problem also occurs. :-|
It's a problem in windows API with .manifest, but i thought that it was fixed in 1.91. Clo, the 1.91 works for you?
Same---
:arrow: Pierre
:) Hello !
…Clo, the 1.91 works for you ?
• No, it doesn't, the bug is there too. I missed it, because this is not a "normal" handling to press both R¦LMB,
but it could occur by accident, so it might be fixed (again).
:mrgreen: KR
Re: Same---
Clo wrote::arrow: Pierre
:) Hello !
So why "It was fixed up, though, I don't know why it came back… "??? :-)
Older---
:arrow: Pierre
:) Hello !
• It has been fixed up really, maybe in a previous version, for sure, but not the 1.91…
- Sorry, I can't remember which one, and I miss time to downgrade to all older versions (a lot).
- I'll try to define the "good" version, and'll post again if I find out it…
:mrgreen: KR
