No thumbnails for JPG files
inl1ner
Post by inl1ner »
the browser shows JPG files not as thumbnails but as XnView-Icons and I couldn't find any option to change this. PNG files are shown as thumbs and if I change the file extension from JPG to PNG the browser shows this file as thumbnail. All other funktions works fine.
Regards inl1ner
Dreamer
Re: No thumbnails for JPG files
Post by Dreamer »
Are you sure that they are real jpg files and not png files?
Try to download some real jpg files from internet...
Also try to disable (unchceck) "Recognize only by extension" in Options > Browser > File List - if this hepls, the files are probably not jpg
inl1ner
You're right ...
Post by inl1ner »
... the related files are no really JPGs because JPGs from my camera are properly shown.
Thanks for your care.
Regards inl1ner
Re: You're right ...
inl1ner wrote:... the related files are no really JPGs because JPGs from my camera are properly shown.
Use Property to know the format.
inl1ner
Properties
Post by inl1ner »
Thank you, files are PNGs.
inl1ner
