Printer selection bug
Flynx
Post by Flynx »
Hi!
This bug occured in 1.91.2, but in my last version (i think 1.90.x) it still worked correctly:
I use Windows XP SP2 and have two network printers. When I want to print something I am able to select the approbiate printer for the task (b/w or color). Then I can change settings for that printer too.
It used to work like this in XnView too, but not anymore: If I select printer 2 and then select settings the new dialog windows opens with the settings of printer 1. Of course I can switch to printer 2 then, but at first I didn't noticed this so this is one cause of possible errors. The big BUG is that even if had selected printer 2 for printing the print job is always done on printer 1. :-(
The dialog for the printer selection seems to be broken; it doesn't notice the new selection (and this behaviour is quit similar to the unit (cm or inch) selector bug I reported some days ago).
Flynx
added information
Post by Flynx »
Oh, I should add, that the selection of a default printer (windows settings) doesn't matter: printer 1 was installed first and even if I set the printer 2 as default printer the print job is done on printer 1 (maybe the order in the registry matters?). Only after deleting printer 1 the job is done on printer 2.
Flynx
Bug already known .... (and will be fixed in next release)
Post by Flynx »
Shame on me . . . sorry!
