Companion file handling
andrewj
Post by andrewj »
Hi, could someone please tell me how to set up the companion file pairs in XnView. On one machine things are working properly, so that if I move a CR2 (Canon RAW) file it moves the JPG as well, but on my laptop it doesn't work.
Thanks
Andrew :?
Re: Companion file handling
andrewj wrote:Hi, could someone please tell me how to set up the companion file pairs in XnView. On one machine things are working properly, so that if I move a CR2 (Canon RAW) file it moves the JPG as well, but on my laptop it doesn't work.
Do you have enabled Option/General/File op/For copy/move use companion...
andrewj
Post by andrewj »
Dear Pierre,
Yes, I have enabled the checkbox. Do I need to do anything else?
Andrew
andrewj
Post by andrewj »
:D
Dear Pierre,
I realised that I was running 1.91.0. I've just downloaded and installed 1.90.4 and it works fine. Sorry to have wasted your time.
Thanks
Andrew
