Thumbnail quality
Danny
Thumbnail quality
Post by Danny »
Not that i care about it, since i'm not using it, but the high quality option for thumbnails doesn't seem to work over here. Make 'em really big (like 300px) and turn on high quality. If you rebuild thumbnails for that folder, the thumbnails will still have low (blocky) quality. Look for areas with high level of detail.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Re: Thumbnail quality
Danny wrote:Not that i care about it, since i'm not using it, but the high quality option for thumbnails doesn't seem to work over here. Make 'em really big (like 300px) and turn on high quality. If you rebuild thumbnails for that folder, the thumbnails will still have low (blocky) quality. Look for areas with high level of detail.
Do you use embedded thumbnail?
Danny
Post by Danny »
I'll have to specify my report: it's always using low quality for folder thumbnails (the one's that give you a preview of the folders contents).
It happens with embedded thumbs both on and off.
