But, is there any way to do this View/Page/Next option within an script?
I been looking for an answer on the forum but I haven't found anything about it, neither an script manual or something similar....any ideas where to look for?
Thank you.
Ok, you would like to 'batch convert' but be able to set page number of readed pdd files!talstog wrote:I have many pdd files, and I would like to make a batch conversion to convert them to png... but to correctly convert them I have to open them, and then View/Page/Next to view the correct image. Once I see the correct image I can do save as to png and it works fine
Yes.xnview wrote: Ok, you would like to 'batch convert' but be able to set page number of readed pdd files!
I'll try to add ittalstog wrote:Yes.xnview wrote: Ok, you would like to 'batch convert' but be able to set page number of readed pdd files!
Is this possible?
