Copy of?
Senorpablo
Copy of?
Post by Senorpablo »
When I copy & paste an image into a directory where the image exists, instead of replacing the file, as it used to, it pastes another version with "copy of..." in the file name.
This is very annoying as I simply want to replace existing files without having to delete them first. Older versions of XnView worked this way, and I'm wondering if there's a setting somewhere to make the new version behave in the old manor?
Thanks
Dreamer
Post by Dreamer »
I support this request.
Dreamer
Re: Copy of?
Senorpablo wrote:When I copy & paste an image into a directory where the image exists, instead of replacing the file, as it used to, it pastes another version with "copy of..." in the file name.
Which old version?? Ok, i'll add an option
Troken
Re: Copy of?
Post by Troken »
Thanks
I do not agree, it's good not to automatically overwrite existing files, simply because many would overwrite wrong files by mistake. The current way is good, works as in windows explorer. There could of course be a dialog, i.e. "Do you want to overwrite ... ?", or options for how to copy/paste - to suite all needs. As default, current way is good.
foxyshadis
Post by foxyshadis »
Explorer never makes "copy of" files unless you copy/paste from the same folder. I agree that it makes sense to be consistent with explorer - in this case it should act the same as drag & drop, popping up the window with the thumbnails to ask what to do. Copy-paste creating copies within a folder makes sense though.
A related quirk is how if you start dragging a file, but decide against it and release back onto the browser window, it'll make a copy. At the minimum, it needs to cancel when you right click, but presumably like explorer, it should only copy if you hold down ctrl, right?
oops66
Re: Copy of?
Post by oops66 »
xnview wrote: Which old version?? Ok, i'll add an option
As an option only, then it's fine for everybody.
XnViewMP Linux X64 - Debian - X64
Dreamer
Post by Dreamer »
I don't want to replace any files automatically, of course, there should be a confirm dialog.
Dreamer
Troken
Post by Troken »
Senorpablo wrote:This is very annoying as I simply want to replace existing files without having to delete them first.
So a pop-up asking to overwrite would solve the problem? (Instead of making copy)? At first I thought you wanted to have the file replaced without warning, but maybe I jumped into conclusions.
foxyshadis wrote:Explorer never makes "copy of" files unless you copy/paste from the same folder.
I stand corrected.
foxyshadis wrote:I agree that it makes sense to be consistent with explorer - in this case it should act the same as drag & drop, popping up the window with the thumbnails to ask what to do.
Precisely, explorers manner should be default, this way all new users wont make bad mistakes.
Senorpablo
I would like the files replaced without warning.
A warning dialog would be better for me than the current implementation, however.
