Moderators: helmut , XnTriq , xnview
ghost zero
Posts: 358 Joined: Mon Feb 05, 2007 8:26 pm
Post
by ghost zero » Sat Oct 20, 2007 2:38 am
How about adding the "rebuild thumbnails" option in the browser right click menu? I find that I have to frequently use this feature to update thumbnails for changed files since they don't rebuild automatically. Thanks.
ckit
Posts: 2583 Joined: Tue Feb 17, 2004 1:11 am
Post
by ckit » Sat Oct 20, 2007 2:43 am
Yes, that's a good idea!
foxyshadis
Posts: 395 Joined: Sat Nov 18, 2006 8:57 am
Post
by foxyshadis » Sat Oct 20, 2007 5:12 am
I think it's a terrible idea. =\
Assigning a shortcut would be a better solution than polluting the menu with a rarely used option (even if a handful of people use it regularly), since we can't customize menus.
ghost zero
Post
by ghost zero » Sat Oct 20, 2007 5:15 am
having a shortcut would be nice, too. but having it conveniently right clickable in the right click menu of the browser makes a lot of sense.
Dreamer
Posts: 4608 Joined: Sun Jul 25, 2004 9:08 pm
Post
by Dreamer » Sat Oct 20, 2007 8:52 pm
I agree with foxyshadis.
BTW we have a shortcut already - Ctrl+R.
If you want to use a mouse, perhaps a toolbar button would be better - it would be customizable.
Dreamer
ghost zero
Post
by ghost zero » Sun Oct 21, 2007 4:15 am
but the Ctrl+R only refreshes folder, doesn't rebuild thumbnails...
Posts: 8704 Joined: Sun Oct 12, 2003 6:47 pm
Post
by helmut » Sun Oct 21, 2007 9:30 am
XnView should update the embedded thumbnail whenever the image's contents have changed. There are many requests regarding updating thumbnails after image manipulation posed here in the forum, already.
Once an update with every image manipulation (and saving) is done, a "Refresh thumbnail" will be needed in few cases, only.
ghost zero
Post
by ghost zero » Sun Oct 21, 2007 4:47 pm
for me, xnview doesn't autoupdate the thumbnails unless the image dimensions change...
Post
by helmut » Sun Oct 21, 2007 4:59 pm
ghost zero wrote: for me, xnview doesn't autoupdate the thumbnails unless the image dimensions change...
Yes, right. My statements "XnView should update" means future versions. The autoupdate should be high up in the "ToDo" list.
Dreamer
Post
by Dreamer » Sun Oct 21, 2007 10:19 pm
ghost zero wrote: but the Ctrl+R only refreshes folder, doesn't rebuild thumbnails...
It looks it works only if cache is disabled.
Dreamer
ghost zero
Post
by ghost zero » Mon Oct 22, 2007 2:56 am
Dreamer wrote: ghost zero wrote: but the Ctrl+R only refreshes folder, doesn't rebuild thumbnails...
is it a bug?
Posts: 46236 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Mon Oct 22, 2007 6:59 am
helmut wrote: ghost zero wrote: for me, xnview doesn't autoupdate the thumbnails unless the image dimensions change...
XnView always auto update if there is a change!!!
ghost zero
Post
by ghost zero » Mon Oct 22, 2007 7:31 am
what is this auto update you guys are talking about?
Post
by xnview » Mon Oct 22, 2007 7:32 am
ghost zero wrote: what is this auto update you guys are talking about?
The function that doesn't work for you, if you change a file, xnview refresh the thumbnails
