Cannot create IPTC metadata for RAF and CR2 files
ectar
Post by ectar »
Cannot create IPTC meta data for RAF and CR2 files.
A have bunch of raw files from Canon and Fuji, but cannot create meta data description to any of them using XnView. Looks like it not supported or I'm doing something wrong. My version is 1.93.1
Re: Cannot create IPTC metadata for RAF and CR2 files
ectar wrote:Cannot create IPTC meta data for RAF and CR2 files.
XnView can only write IPTC in jpeg
ectar
Post by ectar »
Will you consider this features in the nearest future?
ectar wrote:Will you consider this features in the nearest future?
Yes i'll try
