BMP with 32bit is not working
Daniel99
Post by Daniel99 »
Hello...i have a screencapureprogramm and this one makes capture with 32bit BMP.
Wenn i load this BMP and change it to JPG or GIF it always saves a blanck withe image with 3-6kb size !
What am i doing wrong with xnview 1.93.4 german version ?
oops66
Re: BMP with 32bit is not working
Post by oops66 »
Daniel99 wrote:Hello...i have a screencapureprogramm and this one makes capture with 32bit BMP.
You can try this (with v1.93.6):
Enable option/General/Ignore alpha channel
http://newsgroup.xnview.com/viewtopic.php?t=14887
http://newsgroup.xnview.com/viewtopic.p ... =alpha+bmp
XnViewMP Linux X64 - Debian - X64
DanielVV
Post by DanielVV »
I upgrade to 1.93.6 , but still the same problem here.
I can solve it only if i make screenshoot and then include the clipboard into good-old windows paint and save it. (this will save the image as 24bit)...then i can work with it in xnview...
Hmmm i will downgrade to 1.91, i read here, there was no problems like this.
My Guns: winXP Home german, and xnview also in german
DanielVV wrote:I upgrade to 1.93.6 , but still the same problem here.
Your bmp file has a bad alpha channel.
You can enable option/general/Ignore alpha channel
