B1: Image position inconsistency
Dreamer
Post by Dreamer »
- use wide resolution (e.g. 1680x1050, AR 16:10)
- use option "fit image to window, large only" by default
- open large 4:3 image (4MPX) in browser fullscreen
- press num *
= image is centered in the middle
- press ctrl+num * to lock fit
- press page down (to go to 4:3 large image), then page up
= image is NOT centered in the middle, the top left part of image is visible now
The same when using ctrl+num / (lock zoom) instead of lock fit.
When using num 1 (fit to width), image is NOT centered in the middle either.
It should always be the same, or there should be an option IMO.
Dreamer
Re: Image position inconsistency
will be fixed
Dreamer
Post by Dreamer »
OK, but how? What is better? Top left, or middle - or option??
Dreamer
Dreamer wrote:OK, but how? What is better? Top left, or middle - or option??
Must follow the "reset X/Y" setting
Dreamer
Post by Dreamer »
Yes, right.
Dreamer
Dreamer
Post by Dreamer »
Still not working good in beta 3, in fullscreen browser the image is centered correctly, in fullscreen edit position is wrong.
Dreamer
Dreamer
Post by Dreamer »
Still the same in RC1.
Dreamer
Dreamer
Post by Dreamer »
Not fixed in the final release (v1.94). Now the lower right corner is shown.
Moved to Bug Reports.
Dreamer
