Delay every time I open XnView
mariosrib
Post by mariosrib »
Hi
I have xnview at home on XP64 and don't have any problem.
I'm testing now xnview on my company to convince my boss to purchase it, but I'm noticing a very strange problem. Every time I open xnview and browse the directorys on the network, the program seems to crash for 2 or 3 min and after that it works fine.
We have dual quad cores on XP64 and have several network paths mapped.
Is this normal?
Thanks
Re: Delay every time I open XnView
Do you have only the problem with network?
mariosrib
Post by mariosrib »
Hi Xnview
I have just understand that the problem is not on the network.
Every time I open xnview everything works fine if I don't access the menu or click on “page up” or “page down”, I can even browse on the network. The first time I click the menu xnview freezes for 2 or 3 minutes. After that the menu works fine.
If I close the program and open it again the problem happens again.
Can you help me?
Thanks,
Mário
mariosrib wrote:Every time I open xnview everything works fine if I don't access the menu or click on “page up” or “page down”, I can even browse on the network. The first time I click the menu xnview freezes for 2 or 3 minutes. After that the menu works fine.
Can you help me?
Which OS do you have?
Could you try to add in the .ini in [Start] section NoWIA=1
mariosrib
Post by mariosrib »
Hi
I have Windows XP64
Dual quad core 3.0 with 8Gb of ram
I don't know what is the ini that you talk about, could you be more specific?
The only ini file that I have on the xnview directory is "tip.ini"
Thanks,
Mário
xnview.ini is the file for settings, you'll find it in c:\Document settings\...\Application Data\XnView
mariosrib
Post by mariosrib »
Hi Xnview
The problem is solved! :)
I edited the xnview.ini with the line that you sad and never had the menu problem again!
Many Thanks
Mário
mariosrib
Post by mariosrib »
Hi Xnview
I talked to soon... the problem is solved when I see the images in full preview, I can access the menu with no problem, but when I go to browse mode if I access the menu I have the same crash of the 3 minutes! :(
Thanks,
Mário
Artur Muszyński
Post by Artur Muszyński »
I have identical problem. First time I click browser and then any item from menu, XnView "hangs" for exactly 2 minutes. W2003 32 bit, Athlon XP.
Artur Muszyński wrote:I have identical problem. First time I click browser and then any item from menu, XnView "hangs" for exactly 2 minutes. W2003 32 bit, Athlon XP.
Even only the Info menu?
mariosrib
Post by mariosrib »
Hi xnview
Now this problem only happens in browse mode, and it happens the first time I access every menu or do something like a refresh pressing the F5 key.
Could this be an hardware issue?
I have a dual Xeon quadcore 3.0 with 8Gb of ram running on XP64
thanks
Mario
pakk
Post by pakk »
I've a similar problem.
When i open a picture with xnview, it opens instantaneously but i have to wait something like 15-20s to be able to use it.
I've tried the NoWIA=1 tip but the problem is still here.
I have a Q6600, 2go of ram and XP 32bits
I don't have any problem when i launch Xnview with browse mode, but actually i never do that, i always open it when with a picture, i've just tried because i thought it could help you to find the origin of this problem.
Please contact me, i would like to send test version
Artur Muszyński
The same effect is when minimizing or closing browser.
