Tags: Clear all tags / Untag all - Difference
Peter2
Post by Peter2 »
What is the difference between these commands?
Peter
marsh
Re: Tags: Clear all tags / Untag all - Difference
Post by marsh »
Peter2 wrote:What is the difference between these commands?
Peter
Untag all selected in current directory vs clear all tagged files chosen in multiple directories (if options are selected for that function).
Peter2
Post by Peter2 »
Thanks marsh.
Suggestion:
Modify a little bit the menu-strings to make it easier to understand.
Peter
