Draw plugin, howto use it?
drawing guest
Post by drawing guest »
hello,
i downloaded and installed the draw plugin, however i cant seem to get it to work, no toolbar, not selectable in tools->plug-in. what am i missing?
Re: draw plugin, howto use it?
You start the paint tool using menu "Filter > Paint" (in View mode)
drawing guest
thx
Peter2
Using line-feed in TEXT-writing
Post by Peter2 »
I don't want to write long, long lines in paint - plugin -
I want
to write
really short
ones and
empty
lines too.
But I can
not find
the CR/LF
Function and this is why my lines are toooo long.
Where is CR/LF?
Peter
Re: Using line-feed in TEXT-writing
Ctrl+Enter
Peter2
Post by Peter2 »
xnview wrote:Ctrl+Enter
Sorry, no:
The result is the same like "OK(Enter)", closes the dialogue and sets the text in the image.
Peter
Sorry, no:
Oh right!!!
Peter2
Post by Peter2 »
Seem to work in 1.95b.
Peter
