Slow behaviour after XnView start - folder with 'few'
wdolek_
Post by wdolek_ »
hello, i know, this is known issue, and i have tryed to find any answer on this forum, but nothing worked or it was solution which i don't want - disabling such feature...
running on 3GHz processor, 7200 RPM disk, 2GiB RAM... i have folder with more than 100 images in wallpaper resolution - 1200xWhatever ... something like that. avarage image size is 130KiB (JPEG), now, there is exactly 364 files (but issue is notable even with 20 files!)...
i'm browsing directories with file browser such Total Commander or Explorer...
now, i want to start viewing image, i "run" first one in directory. xnview starts quickly and show that image - but then it starts caching (?) or do "something" - after start, i'm not able to move to next image... i have to wait ... 1 minute (only 364 files!), then xnview "unfreeze".
i had turned off cache, recognizing by extension is set, ... i have tryed to turn off loading of next image... but still - when i start xnview, i just see how disk seeking.
do not know, where to turn off this feature... and i must say, that this "precache" or whatever feature is :P ... ... when i wait that long minute, still, loading of next / prev image is not so quick as it should be...
please, tell me where to find answer...
PS
i'm using "sort by type" - when i'm using xnview browser, files are sorted differently than when i'm viewing them in viewer :P why?!
oops66
Re: slow behaviour after xnview start - folder with "fe
Post by oops66 »
To speed up your xnview start into the browser mode, you have to enable the Xnview Thumbnails cache "options\thumbnails\cache\enable caching --> lossless zip".
If not, the thumbnails into your customized starting directory will be recreated each times.
By this way you should reduce the starting time from 1 minutes to ~20 seconds.
(If you still have the 1 minute, you can also try to rename (or delete) your category.db file, to see if it's better )
wdolek
Post by wdolek »
oops66: well, i have tryed it too, but still the same - xnview freezes, disk seeks and cpu is on 100% :( (with thumbnails stored!)... i have also tryed to set "compression" to "none" ... but still the same...
in browser i'm using "detail" list - no "thumbnail" ... but i'm starting directly to preview - so there is no need to create thumbnails... and turning off reading of headers also did not help at all...
oops66
Post by oops66 »
wdolek wrote:...in browser i'm using "detail" list - no "thumbnail" ... but i'm starting directly to preview - so there is no need to create thumbnails... and turning off reading of headers also did not help at all...
Yes, in this case the cache is not needed.
Your problem is very strange, and you are on which OS and which XnView Version ?
(Did you try to erase xnview.db too, or reinstall XnView )
wdolek
Post by wdolek »
running on windows xp pro, and this strange behave is there... well... few years :P i'm using the newest version (1.93.6), i'm updating time to time. i'm using on my computer(s) application from zip file... but i have installed xnview to friends from exe installator and same problem... when updating, i remove all files from ~/Local Settings/Temp and also whole XnView directory, everytime just new clear, brand new :) installation... i don't think so that this is just my problem...
maybe i just use xnview bit differently (?)... browser with "detail list" not with thumbs, and running xnview directly into "preview" from explorer (or whatever) by "running" image file...
really - i see how disk is seeking when "run" any image on directory. xnview maybe looks what is on directory... but this should be fast - any list of files. xnview does more than "list files from directory" i think... :(
there is my ini file... maybe that few years i forgot to set something (?)...
[AutoCrop]
Tolerance=0
[Browser]
ActionConvert=0
ActionSlide=1
ArrangeBy=4
AutoCollapse=0
AutoPlay=0
BColorFilter01=jpeg, 237 237 202
BColorFilter02=gif, 220 235 220
BColorFilter03=png, 232 222 220
BColorFilter04=bmp, 227 227 255
BColorFilter05=tiff, 192 197 235
BColorFilter06=tga, 230 255 255
BColorFilter07=iff, 247 235 235
BColorFilter08=sgi, 247 237 242
BColorFilter09=pcx, 235 230 230
BColorFilter10=psd, 255 255 227
BColorFilter11=pcd, 235 215 235
BColorFilter12=psp, 237 208 163
BColorFilter13=pict, 202 202 255
BColorFilter14=xpm, 242 227 21
BColorFilter15=xbm, 216 216 216
BColorFilter16=pbm, 191 191 182
BColorFilter17=pgm, 207 207 197
BColorFilter18=ppm, 235 225 159
BColorFilter19=ras, 255 255 227
BColorFilter20=wmf, 187 187 187
BColorFilter21=emf, 212 212 212
BColorFilter22=ico, 217 247 227
BColorFilter23=cur, 217 247 227
BColorFilter24=ani, 217 247 227
BColorFilter25=fpx, 229 255 255
BColorFilter26=jp2, 237 237 202
BackListColor=16777215
BackgroundColor=16777215
BorderColor=0
BorderSize=0
CRAW=0
ClickRename=0
Custom0=<Focal>mm f/<F> <Exposure>s <ISO>iso
Custom1=<Width>x<Height> - <Size>
Custom2=
Custom3=
Custom4=
EnableAutoRefresh=1
FilterBy=4
FitVideo=0
FitWindowOption=1
FlatStyle=0
FollowLink=0
FullPreview=0
FullRowSelect=1
Height=675
HidePreviewScrollBar=0
HighQuality=0
IconHeight=144
IconInfo=2039
IconWidth=192
InfoO-0=1
InfoO-1=1
InfoO-10=1
InfoO-11=1
InfoO-12=1
InfoO-13=1
InfoO-14=1
InfoO-2=1
InfoO-3=1
InfoO-4=1
InfoO-5=1
InfoO-6=1
InfoO-7=1
InfoO-8=1
InfoO-9=1
LabelsAlignment=1
LabelsSpacing=1
Layout=3
ListHeight=256
ListViewHeight=648
ListViewWidth=932
ListWidth=233
NavigateSubFolder=0
OldTreeTab=0
OldValue=0
OneClick=1
OpenAction0=0
OpenAction1=1
OpenAction2=1
OpenAction3=1
OpenAction4=1
OpenAction5=1
OpenAction6=1
PreviewColor=8421504
PreviewHeight=308
PreviewWidth=0
PrintInfo=1
RecognizeByExt=1
RenameHideExtension=0
RotationKeepData=1
RotationUseEXIF=1
RotationUseLossless=1
ScanHeaders=3
SelectLastAddedFiles=0
SharpenThumb=0
SharpenValue=50
ShowDesktop=1
ShowDirList=1
ShowFilename=1
ShowGridLines=1
ShowHexaView=0
ShowHiddenFile=0
ShowPreview=1
ShowSmallToolbar=1
ShowTabTree=1
ShowTabView=1
ShowToolTips=0
Spacing=4
StartupDirectory=
StartupIn=0
StatusInfo=0
SyncWithView=1
TabTreeLabel=1
TagSetting=1
TextBackColor=12632256
TextColor=0
Thumb41Folder=0
ThumbConfig=10 5 50
ThumbGamma=1.00
ThumbnailColor=16777215
TimerForPreview=200
TooltipText=<Filename>, <Size> bytů, <Modified>||<Format>||<Width>x<Height>, <BPP> bitů
TreeViewHeight=334
TreeViewWidth=342
TxtExt=txt c c++ cc h cpp pas js css php ini
UpdateTreeViewWhenRefresh=1
UseBackgroundColor=0
UseBytes=0
UseColor=1
UseFileDB=1
UseGammaOnThumb=0
UseInch=0
UseRating=1
UseRenameDlg=1
UseShadow=1
UseTag=0
UseThumbnailColor=0
VHidePanel=1
VListLayout=0
VideoFrame=0
VideoPlayBar=1
ViewColumn=255
Viewas=2
Width=1288
X=0
Y=0
column0=249
column1=88
column10=0
column2=120
column3=240
column4=104
column5=384
column6=384
column7=48
column8=0
column9=0
tcolumn0=314
tcolumn1=196
tcolumn2=338
tcolumn3=384
[Cache]
Compression=0
IsActive=1
MaxDir=99
SavingMode=0
[Canvas]
KeepRatio=1
Position=4
[Capture]
Area=2
ClientArea=0
Delay=5
Directory=D:\
FormatName=jpeg
HideCursor=0
HideXnView=1
HotKey=11
IncludeCursor=1
Method=1
Multiple=1
SaveIntoFile=1
[Colors]
Auto=0
Count=0
Dither=0
[ContactSheet]
Columns=4
Flags=4
FontBold=0
FontHeight=-13
FontItalic=0
FontName=Courier
FootNote=
HeadNote=
Height=1000
MarginHeight=16
MarginWidth=16
Rows=4
SpacingHeight=8
SpacingWidth=8
Text=<Filename>
TextBackgroundColor=16777215
TextColor=0
ThumbnailBackgroundColor=12632256
Width=1000
[Convert]
CloseDlg=1
DefaultFormat=jpeg
DeleteOriginal=0
HideError=0
KeepFormat=0
KeepOriginalDate=1
KeepSubFolder=1
Overwrite=0
UseOrgPath=0
[File]
ConfirmFileDelete=1
CopyCompanionFile=1
CopyTo=
DeleteRecycleBin=1
DirName_0=
DirName_1=
DirName_2=
DirName_3=
DirName_4=
DirName_5=
DirName_6=
DirName_7=
DirName_8=
DirName_9=
KeepDate=1
MoveTo=
PasteNoCopy=0
[FileSelector]
IncludeSubDirectories=0
[Full]
BackColor=0
DualMStretch=0
DualMUse=1
Fit=0
HidePlayBar=0
HideScrollBar=1
SizeDelay=2048
UseDelay=1
[Fullscreen]
FontBold=0
FontCharSet=1
FontHeight=-13
FontItalic=0
FontName=Courier
IsTransparent=1
Position=0
TextBackColor=0
TextColor=16777215
[Install]
ViewAsName=1
[Load]
CRAWAutoBalance=0
CRAWBlueScaling=1.00
CRAWBrightness=0.80
CRAWCameraAutoBright=1
CRAWCameraBalance=1
CRAWGamma=0.60
CRAWHighResolution=0
CRAWRedScaling=1.00
ChannelOrder=0
ChannelType=1
DjVuMaxDpi=0
EXIFDpi=0
EXIFRotate=1
ExrGamma=1.00
GrobBpp=0
HdrGamma=1.00
Height=256
ICCProfile=0
ICCProfileName=
IcoIn32bits=1
IgnoreError=0
Lut10to8Name=
Offset=0
PcdBase=2
PddPage=0
PngComposeWithAlpha=0
PngComposeWithTransparency=0
PostscriptDpi=72
PostscriptPageSize=0
Preview=1
UseEmbeddedThumbnail=1
UseLut=0
UseOrgIfSmall=0
WMFHighResolution=0
Width=256
YuvHeight=576
YuvOffset=0
YuvWidth=720
[OpenWith]
OpenWith_0=
[Player]
SoundOn=1
Volume=100
[Plugins]
0=Xawd.dll|276|awd|AWD|awd;
1=Xbmf.dll|262|bmf|BMF|bmf;
10=Xfpx.dll|788|fpx|FlashPix Format|fpx;
11=Xiwc.dll|773|iwc|WaveL|iwc;
12=Xjbig.dll|772|jbig|JBIG|jbg;bie;jbig;
13=Xjng.dll|261|jng|Jpeg Network Graphics|jng;
14=Xjng.dll|261|mng2|Multiple Network Graphics|mng;
15=Xjp2.dll|773|jp2|JPEG-2000 JP2 File Format|jp2;j2k;jpx;jpf;
16=Xjp2.dll|773|jpc|JPEG-2000 Code Stream|jpc;
17=Xjpegls.dll|262|jls|JPEG-LS|jls;
18=XMrSid.dll|276|sid|MrSid|sid;
19=Xp2.dll|263|p2|Pic2|p2;
2=Xbsb.dll|262|kap|BSB/KAP|kap;
20=Xpax.dll|262|pax|PAX|pax;
21=Xpwc.dll|263|pwc|Fast Piecewise-constant|pwc;
22=Xsff.dll|261|sff|Structured Fax Format|sff;
23=Xwhypic.dll|262|ypc|Whypic|ypc;
24=Xwic.dll|774|wic|J Wavelet Image Codec|wic;
25=Xwlm.dll|774|wlm|CompW|wlm;
26=Xwmp.dll|772|wmp|HD Photo|wdp;hdp;
3=Xcompound.dll|276|max|3DS Max thumbnail|max;
4=Xcompound.dll|276|mic|Microsoft Image Composer|mic;
5=Xcompound.dll|276|mix|Picture It!|mix;
6=Xdjvu.dll|276|djvu|DjVu|djvu;djv;iw4;
7=Xecw.dll|775|ecw|Enhanced Compressed Wavelet|ecw;
8=Xeri.dll|263|eri|ERI-chan (Entis Rasterized Image)|eri;
9=Xfif.dll|263|fif|FIF (Iterated System)|fif;
Nb=27
[Print]
AllPages=0
AutoRotate=1
BottomMargin=0.20
CType=0
Columns=4
EFontBold=0
EFontHeight=10
EFontItalic=0
EFontName=Courier
ETextColor=0
FText=Page <Page>/<Page>
FontBold=0
FontHeight=10
FontItalic=0
FontName=Arial
Gamma=1.00
HText=
Height=10.00
HoriSpacing=1.00
KeepRatio=0
LeftMargin=0.20
Multiple=0
Option=0
Position=4
RightMargin=0.20
Rows=4
Text=
TextColor=0
TextPosition=0
TopMargin=0.20
Units=0
UseFooter=0
UseHeader=0
VertSpacing=1.00
WFontBold=0
WFontHeight=10
WFontItalic=0
WFontName=Courier
WFontOrientation=0
WOrientation=0
WText=
WTextColor=0
WTextPosition=0
WUse=0
Width=15.00
XScale=2.00
YScale=2.00
[Process]
AutoView=1
Deinterlace=0
FilterAutoView=1
Last=3
LastValue_0=0
LastValue_1=0
LastValue_10=1
LastValue_11=-255
LastValue_12=-255
LastValue_13=-255
LastValue_14=-255
LastValue_15=-255
LastValue_16=-255
LastValue_17=-255
LastValue_18=-255
LastValue_19=0
LastValue_2=100
LastValue_20=0
LastValue_21=0
LastValue_22=-255
LastValue_23=-255
LastValue_24=-255
LastValue_25=0
LastValue_26=3
LastValue_27=13
LastValue_28=-255
LastValue_29=-255
LastValue_3=-255
LastValue_30=-255
LastValue_31=-255
LastValue_32=-255
LastValue_33=-255
LastValue_34=-255
LastValue_35=0
LastValue_36=0
LastValue_37=0
LastValue_38=-255
LastValue_39=-255
LastValue_4=-255
LastValue_40=-255
LastValue_41=-255
LastValue_42=-255
LastValue_43=-255
LastValue_44=-255
LastValue_5=-255
LastValue_6=-255
LastValue_7=-255
LastValue_8=-255
LastValue_9=-255
ShowPreview=1
[Rename]
CaseFlag=4
Extension=jpg
RCase=0
Replace=
Start=1
Step=1
TCreate=0
Template0=<Date>_<Filename>
Template1=name-#
Template10=
Template11=
Template12=
Template13=
Template14=
Template15=
Template16=
Template17=
Template18=
Template19=
Template2=
Template3=
Template4=
Template5=
Template6=
Template7=
Template8=
Template9=
UseCase=1
UseExtension=0
UseReplace=0
UseTemplate=1
With=
added=0
numbers=1
suffix=_##
[Resize]
DpiUnit=0
KeepDocSize=0
KeepRatio=1
PrintUnit=0
Resample=1
Unit=1
[Save]
AddExtensionIfNotExist=1
BmpCompress=0
ChannelOrder=0
ChannelType=1
DefaultFormat=png
DpxIn10Bits=0
DpxMSBF=0
EcwTargetRatio=20
FpxQuality=100
Gif87aHeader=0
GifInterlaced=0
GifTransparentIndex=0
GifUseTransparentIndex=0
Hp49Header=0
IffCompress=0
IwcQuality=100
Jpeg2000FileSize=100
Jpeg2000Mode=1
Jpeg2000Quality=90
Jpeg2000Ratio=10
JpegDCTMethod=2
JpegKeepEXIF=1
JpegKeepIPTC=0
JpegProgressive=1
JpegQuality=90
JpegRebuildThumb=0
JpegSmoothFactor=0
JpegSubSampling=2
KeepOrgDate=0
LdfAddThumbnail=1
LdfQuality=2
LdfjpmBackFactors=1
LdfjpmBitonalCoder=2
LdfjpmForeFactors=1
LdfjpmQuality=8
Lut8to10Name=
LwfCompression=0
LwfJp2Compression=0
LwfJp2Rate=10
LwfJp2Size=4096
LwfMode=0
LwfQuality=70
LwfRate=10
LwfSize=1024
Offset=0
OptimizeHuffmanTable=0
Os2Header=1
PcxCompress=0
PdfCompress=4
PdfJpegQuality=90
PngCompressionLevel=6
PngInterlaced=0
PngTransparentIndex=0
PngUseTransparentIndex=0
PpmAscii=0
RgbCompress=1
SoftCompress=1
TgaCompress=0
Tiff1Strip=0
TiffBinaryCompress=3
TiffCompress=0
UseLut=0
UseOrgJPEGQuality=0
WMPQuality=100
WicQuality=100
WlmFactor=1
[Scan]
Digit=3
Directory=D:\
FileName=scan_
FormatName=jpeg
Multi=0
Page=0
StartIndex=1
Subfolder=1
[Scr]
PlayMode=0
WindowHeight=480
WindowWidth=640
[Slide]
AudioLoop=0
BackgroundColor=0
Center=1
EffectFlag=1
EffectMask=268435455
FitSmall=0
FitSmallVideo=0
FontBold=0
FontCharSet=1
FontHeight=-13
FontItalic=0
FontName=Courier
Full=1
HighQuality=1
IsTransparent=1
Loop=1
NoError=0
NoTitle=1
Position=0
Random=0
SLDRelativePathname=0
ShowText=1
SortOder=0
SoundFilename=
Text=<Directory><Filename>
TextBackColor=0
TextColor=16777215
Timer=5.00
UseGammaInEXE=1
UseSound=0
UseTimer=1
[Start]
AllFormats=1
AlwaysOnTop=0
BStatusBar=1
BToolBar=1
BarFilename=
CColor-0=0
CColor-1=0
CColor-10=0
CColor-11=0
CColor-12=0
CColor-13=0
CColor-14=0
CColor-15=0
CColor-2=0
CColor-3=0
CColor-4=0
CColor-5=0
CColor-6=0
CColor-7=0
CColor-8=0
CColor-9=0
CheckUpdate=3
Custom1Extensions=HTM HTML MHT MHTML XML XHTML EML NWS URL
Custom2Extensions=
CustomIniPathFolder=
DirName_0=D:\photos\digi\2008-07-28_slovensko\
DirName_1=D:\photos\digi\2008-07-28_slovensko\wf\
DirName_2=D:\photos\digi\
DirName_3=D:\photos\
DirName_4=D:\files\
DirName_5=D:\
DirName_6=C:\
DirName_7=C:\Documents and Settings\Zdenek\
DirName_8=D:\files\wallpapers\
DirName_9=
ENTER=1
FileName_4=
FileName_5=
FileName_6=
FileName_7=
FileName_8=
FileName_9=
Filter0=639
Filter1=895
Filter2=588
Filter3=287
FlatButtonInToolbar=1
Height=600
InFullscreen=0
LMB=1
Language=en
LastCheck=20315124
LaunchBrowserAtStartup=0
MMB=0
MaxFilesize0=999999
MaxFilesize1=999999
Maxi=1
MaximizeXnviewAtStartup=1
MenuUseExit=0
Only1ESC=1
OnlyOneInstance=1
OpenAll=1
ParamsSavingMode=1
PathAvi=
PathBrowse=D:\photos\digi\2008-07-28_slovensko\
PathCache=
PathConvertSave=./wf
PathLoad=
PathPalette=
PathSave=C:\Documents and Settings\Zdenek\Plocha\
PathScript=
PathSlide=
PathSlideScript=
PurgeMostRecentlyUsed=0
SaveAsUseNewName=1
SavePosition=1
SavedFileType=:gif:jpeg:png:tiff:bmp:emf:pcx:jp2:lwf:
SavingMode=1
ShowAgain=268435423
ShowSaveDlg=0
ShowTextInToolbar=0
ShowToolTipsInToolbar=1
TabBar=1
TabBarCfg=3
TabBarDefault=0
TabBarMaxChar=32
TagShowFlags=0
ToolbarBrowserConfig=-1
ToolbarBrowserConfigHigh=-1
ToolbarName=mezich
ToolbarViewConfig=-1
ToolbarViewConfigHigh=-1
UseDifferentPosition=0
UseExtendedMenu=0
UseMostRecentlyUsedFiles=0
UseNewMRUF=1
UseSameAsOrg=1
VStatusBar=1
VToolBar=1
Version=193
ViewHeight=600
ViewMaxi=1
ViewWidth=960
ViewX=160
ViewY=100
Width=960
X=160
Y=100
[View]
AppFitToImage=0
BackColor=0
BackgroundColor=8421504
CRAW=0
CacheBehind=1
ColorInfo=0
CopyClipboard=0
DeleteGoNext=1
DirKeyFlag=1
DirKeyVFlag=2
DisableGifAnimation=0
EnableBmpAnimation=0
Fit=3
Gamma=1.00
GridColor=255
GridSize=2
GridSpacingX=80
GridSpacingY=80
GridType=1
HideScrollBar=0
HighZoomQuality=1
IgnoreAlpha=0
ImageLoop=0
KeepGridForNextPrevious=0
LeftButtonFlag=1
LockZoom=0
MouseNavigation=0
NoMultipleView=1
OneViewMultiple=0
OnlyOneView=0
OpenHexaViewIfNotPicture=0
PlayMovie=1
PlaySound=1
ReadAhead=1
ResetXY=0
RightButtonFlag=0
ScrollVal=10
ShowColorInfo=0
ShowText=1
SlideDelay=1000
SlideDirection=0
SlideLoop=1
SpaceKeyFlag=0
StatusInfo=0
Text=<Directory><Filename>||Tag: <Tag>
UnitsSize=0
UseAlpha=1
UseBgImg=0
UseDPIRatio=1
UseGamma=0
UseTranspIndex=1
UseUndo=1
UseZoomStep=0
UserSelHeight=0
UserSelRatioX=0
UserSelRatioY=0
UserSelWidth=0
UserSelXdpi=0
UserSelYdpi=0
VideoFitAll=0
VideoLoop=0
VideoPlayBar=1
WheelMouseFlag=2
ZoomStep=10
[Watermark]
Auto=0
Hspace=0
NoAlpha=0
Path=
Pos=4
Transp=100
Vspace=0
bmezenga
Post by bmezenga »
oops66 wrote:(Did you try to erase xnview.db too, or reinstall XnView )
wdolek wrote:when updating, i remove all files from ~/Local Settings/Temp and also whole XnView directory, everytime just new clear, brand new :) installation... i don't think so that this is just my problem...
wdolek; there are other files/directories to worry. Please take a look HERE about another database file (category.db) and the windows user directory.
wdolek
Post by wdolek »
bmezenga: .. umm.. i think i removed all files and records: registry records (associations and shell extension), main xnview directory on "program files", temp directory, and of course xnview directory from ~ directory... (well - have to say - i'm using single-user installation). there is no file left before i start new installation... (i was also trying to find any "category.db" file on hdd - without any match)
today, i installed 1.94.2 from .exe installator and... it is still the same. i double-click on image file, xnview starts showing image, CPU is on 100%, i can not get on next / prev image for many many many seconds (maybe minutes), gui is completely frozen...
wdolek wrote: today, i installed 1.94.2 from .exe installator and... it is still the same. i double-click on image file, xnview starts showing image, CPU is on 100%, i can not get on next / prev image for many many many seconds (maybe minutes), gui is completely frozen...
Could you try to disabled "read ahead"?
wdolek
Post by wdolek »
xnview: nope it didn't help neither...
is there any debug build of xnview which makes some logs? i would really like to know, what xnview is making when started to "view" directly...
Does the browsed directory contain only JPG files? Has the directory subfolders?
wdolek
Post by wdolek »
helmut wrote:Does the browsed directory contain only JPG files? Has the directory subfolders?
nope, on this case, there is just directory with .jpg files and .png files ... no subfolders. and no matter if there are only 20 .jpg files or 400 .jpeg files - lag of entire gui is there in both cases...
i must specify more this issue... if i "run" directly to view, i can zoom in / out ... and do every stuff with this one image fastly... but when i want to go to previous or next image (clicking to arrows or using pgup / pgdn) - on this, cpu is on 100% and xnview starts caching (?) directory or what... but :P as i told - i don't use thumbnails, i have turned "read image above" off, i turned "reading headers" off and also there is recognizing only by extension... there is no reason to lag entire gui and make cpu on 100% for one minute X-( !
In option/General/Startup, you use 'Fullscreen - edit'?
Post by Guest »
hm, i think i found the reason for this odd behaviour: "Sort by Type" (ArrangeBy=4 in line 7 of xnview.ini)
when files are set to be sorted by something other than "Type", everything works fine ... at least for me :P
Art535
scan
Post by Art535 »
Try:
Options > BROWSER > File List > Scan File Headers in Folders
Select from drop down: Never
Program will list all files in folder but will not scan them individually.
I tried this with a folder of 5,000 + files with no delay.
Works for me!
