Color instead of deleted part of the picture
wanderwegmarke
Post by wanderwegmarke »
If you delete a part of the picture, is there an option to select the background color of the empty part of the picture? Thank you from wanderwegmarke
Re: Color instead of deleted part of the picture
wanderwegmarke wrote:If you delete a part of the picture, is there an option to select the background color of the empty part of the picture? Thank you from wanderwegmarke
No, setting a background colour which is used when deleting a part of the picture is not supported.
A bit complicated workaround:
What you could do is mark a small area of this (or another image) which has the colour you want as background and copy it it to the clipboard. Then you select the area which you want to delete and paste the clipboard to the current selection ("Edit > Paste", or Ctrl+V).
