May i lock the splitter bar?
allan
Post by allan »
as title, may i lock the splitter bar?
thanks :shock:
Re: may i lock the splitter bar?
you would like to lock the splitter?
allan
Post by allan »
yes ~ i hope there has a setting to do lock or not ~
allan wrote:yes ~ i hope there has a setting to do lock or not ~
I'll add an option
Post by Guest »
thank you very much :P
lian
Post by lian »
It seems locked by default. Where is the option hidden ?
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Dreamer
Post by Dreamer »
lian wrote:It seems locked by default.
Yes, but it shouldn't be locked by default IMO, also because it's not easy to change this hidden option for normal users.
To unlock it, first close XnView, then open the xnview.ini file in notepad, find option LockLayout=1 , change the value to 0 and save the file.
Default value should be definitely 0 IMHO!!!
Dreamer
Ab_so_lu_te_ly
:arrow: Dreamer
:) Hello !
Absolutely !  I support strongly such a wish !
:mrgreen: KR
lian
Post by lian »
I took a look in my register and it was fixed on value 1.
Dreamer wrote:Default value should be definitely 0 IMHO!!!
Default value is already 0
Dreamer
Post by Dreamer »
I tried it with very old ini and it's 0, strange. :?
Dreamer
It was not !
:arrow: Dreamer
:) Hello !
• Well, now it seems that the default is alright “0”, but it wasn't in the 1.96-ß-1,
I had even to START A THREAD because I missed to check that INI entry… Please, see also the last message.
• Further -and still on_topic- we miss means to use that feature easily, for those who need it :
1. An internal command for a button (for a shortcut and¦or a menu item, send a petition to Santa Claus),
to toggle that ON and OFF quickly.
2. To preset certain sizes of the panes, another command to save them on the fly, being sure they are saved.
Then, one could lock again, on the fly too.
:mrgreen: KR
oops66
Re: It was not !
Post by oops66 »
Clo wrote:... to toggle that ON and OFF quickly..
I fully agree to have the ability to toggle this function ON and OFF quickly (with a new menu option, but not only into the .ini file).
Already discussed here at the v1.96 beta stage:
http://newsgroup.xnview.com/viewtopic.php?p=70569#70569
Commands and management
:arrow: oops66
:) Hello !
• Well, in the thread you quote, only a GUI option was suggested…
IMHO, a couple of internal commands could do the trick too, something like:
cmd_LockBrowserSplitters (bistable).
cmd_SavePresetLayout
… and indeed like I repeat endlessly for years, a decent commands manager, languages and menus as text etc. … 8)
(Sigh…)
:mrgreen: KR
oops66
Re: Commands and management
Post by oops66 »
Clo wrote:... in the thread you quote, only a GUI option was suggested… IMHO, a couple of internal commands could do the trick too...
You are right Clo, but an internal command associated with a customized icon into the toolbar is also a GUI option !
But basically, I prefer the internal commands way too, optionally coupled with a new menu setting.
