Custom Print Format 4cm x 5 cm
jasonmillman
Post by jasonmillman »
Hi, I'd like to print multiple images in 4cm x 5cm format (for a plastic filmstrip I bought that has 20 windows of this size to fill with photos), but can't find or figure out how to do this, as the 4x5 format is not an option that I can find. Can you please help?
Re: Custom Print Format 4cm x 5 cm
Use 'Single - custom'
Post by Guest »
Pierre, thanks for the quick response, this only allows a single 4x5 image to be printed on the entire page (and centered), rather than fitting as many 4x5 images on the page as possible, as with the other templates. Anything I can do?
I must add custom size
oops66
fitting as many (custom size) images on the page
Post by oops66 »
xnview wrote:I must add custom size
I support this request.
But maybe the best way is to add a custom size into the Page Layout tab "Picture collection" ???
FI: I have a strange behavior(bug) into this layout (Picture collection):
Case 1: only one image is selected (or tagged) and :
If "Multiple Images per page" is checked => I have only a single image.
If "Multiple Images per page" is unchecked => I have multiple images.
Logically , the right behavior is the opposite.
Case 2: several images are selected (or tagged)
Better but the behavior is not as expected too.
In fact, i think the best way is to rename : "Multiple Images per page" to " Single image(s) per page", what do you think ?
