Filter
Pappnase
Filter
Post by Pappnase »
I'm using Xnview since half a year for the extinction of any metadata on jpg.
Since then I'm trying to find a possibilty to use "user defined" filters.
Sorry I'm a blockhead. I cant find the "how to define a filter"
I only find the "use"button.
I did't find something useful via "search" either.
So please help a silly blockhead.
sorry t'was me who made the mistake
Welcome, Pappnase :o)
In View mode, go to Filter » User filter....
Pappnase
Post by Pappnase »
view\filter\usefilter
perhaps the same as
Ansicht\Filter\benutzerdefiniert
nothing happens - it could be, the ussage of user defined filters
(I think so)
But where to define the filters?
sorry: Win2K SP4 ge
Pappnase wrote:view\filter\usefilter
perhaps the same as
Yes.
Pappnase wrote:But where to define the filters?
A dialog window titled “Benutzerdefinierter Filter” (“User Filter”) should pop up, when you click on Benutzerdefiniert... in the Filter menu:
  • Image
All user-defined filters are saved in a text file (%ProgramFiles%\XnView\Filters\udf-def.dat):
# XnView UDF v1.0 (do not edit)
average 3 | 3 1 0 | 1x9
average 5 | 5 25 0 | 1x25
blur | 3 16 0 | 1 2 1 2 4 2 1 2 1
emboss | 3 1 128 | -1 0x7 -1
Help online---
:arrow: Pappnase
:) Hello !
• I guess that a glance HERE could help… :wink:
:mrgreen: VG
Pappnase
Post by Pappnase »
Nothing happens
could this be a result of my paranoitic defensive system settings?
What have I to allow?
This should be an "inside" problem no "outside" ala Microsoft with all borders goin' down.
Pappnase wrote:could this be a result of my paranoitic defensive system settings?
Well, you need to have read and write permissions for udf-def.dat.
Pappnase
Post by Pappnase »
I'm Admin on my pc, I may install an use anything.
I made a normal instal.
So where is the problem?
*a lil bit flabbergasted*
Can you open udf-def.dat with Notepad?
Pappnase
Post by Pappnase »
No, also it is on my computer it ain't disployed with "öffnen mit"
I can open it with wordpad were the following is shown:
