toolbar commands
obelisk
toolbar commands
Post by obelisk »
Adding new toolbar commands for things w/o icons, you have to choose an icon from a file. Why not let us choose from existing toolbar icons? Eg resize - I could use a zoom icon for it. Whereas there's nothing in the exe that's usable :P
Patterns are stuck---
:arrow: obelisk
:) Hello !
• I guess that isn't possible : Currently, each patten on any skin bitmap(main.bmp) stands for a defined command only,
that you can check in your *.bar file. Every button set with a pattern doesn't show the command in its line, it's implicit…
• Other snags :
1. The authors of skins don't provide extra icons as *.ICO or ICL, I think they would.
I provide matching *.ICO sets, but I'm the only, alas :|
2. Multipage icons - that we can create in XnView - are not supported for all pages (only the first is),
same for other containers like multipage TIFF (not at all) and standalone *.BMP…
• Finally, there are too some bugs¦lacunaæ in the configuration dialogue-box never fixed¦filled in (i.e. the wrong preview size in some cases).
- It isn't a big deal to draw some missing extra icons… Needs just ideas to find meaningful patterns… :P
:mrgreen: KR
obelisk
Post by obelisk »
well map
cmd_Resize and cmd_CanvasResize [ Canvas size... ]->cmd_Fullscreen [ Fullscreen ]
reuse the existing icon with ease! :wink:
better icon than none at all
