Purge 'Most recently used files&dirs' on exit
Dreamer
Post by Dreamer »
Another important option from XnView Windows: "Purge 'Most recently used files & directories' on exit". Privacy is very important for some users, especially if more users are using the same computer.
Another similar option: "Show 'Most recently used files' in File menu".
Dreamer
marsh
Re: Request - Purge 'Most recently used files&dirs' on exit
Post by marsh »
Using some version, I thought it was useful to clear the filenames, not the folder history. Because I never erased folders (and wanted to return to them in small toolbar history), but images were often erased (so pointless to have a history of these anywhere).
Dreamer
Post by Dreamer »
Then 2 options, but it should be possible to remove all history entries too.
Dreamer
budz45
Post by budz45 »
I agree with Dreamer
Dreamer
Post by Dreamer »
In 0.85b1 the option was added, but some path(s?) are still not removed, e.g.:
PathBrowser=
It's not so important for me now, but since we have the option "Purge 'Recent files and folders' on exit", it should purge also folders.
Dreamer
Dreamer wrote:In 0.85b1 the option was added, but some path(s?) are still not removed, e.g.:
PathBrowser=
Thank you for checking, Dreamer. This is a bug which should be fixed.
:arrow: Bug reports - New
Re: Purge 'Most recently used files&dirs' on exit
I can confirm that PathBrowser is not reset when using [x] Purge "Recent files and fodler" on exit in Settings: Interface | Interface.
:arrow: Reproduced
Dreamer
Post by Dreamer »
Another path is not removed, probably created when converting an image. :bug:
InputPathname=
Dreamer
O.k., thank you, I can also reproduce the problem. Issue 1224 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Dreamer
Post by Dreamer »
Confirmed, fixed in 0.87 beta 1, thanks, Pierre.
:arrow: Closed.
Dreamer
Dreamer
Post by Dreamer »
Re-opened, this path is not removed in beta 2, automatically on exit or manually using "purge now" button. Batch convert, output, folder, last used path.
[Convert]
History=
Dreamer
ok, will be fixed in beta 3
Dreamer
Post by Dreamer »
Fix confirmed in beta 3 (not released yet), thanks, Pierre.
:arrow: Closed.
Dreamer
