Please help me with color management in XnView.
Lakoz
Post by Lakoz »
I do not understand how to use ICC profiles. Does Xnview automaticly use monitor ICC profile assigned directly in ms windows color management settings? Or no? What about working spaces and output profiles (let's say for printers)? Can you explain me color management settings implemented in Xnview? I use color profiling in Adobe products and it is very easy to understand it there.
Thank you very much.
Re: Pleas, help me with color management in XnView.
Lakoz
Post by Lakoz »
So, when I turn color management in Xnview on, I have to define my monitor ICC profile in the first box on ICC tab. Default ICC profile (second part of ICC tab) is used only for files without embended profile. When the profile is embended directly in the file, Xnview uses that embended profile and not the default ICC profile. Do I uderstand it correctly? So I think, Xnview does not use color management implemented directly in operating system. Am I correct? And what about printer profiles?
Thank you.
Lakoz wrote:So I think, Xnview does not use color management implemented directly in operating system. Am I correct?
Yes
Currently not supported
