Keyboard, Switching Modes, Use Enter key to switch between: Browser <> Fullscreen | Viewer <> Full screen
Full screen, auto image size: No Fit
View, Auto image size: No fit
View, Reset X/Y: checked
Lock Zoom: disabled
From the viewer, if I find an image too tall for the screen, I press enter to view fullscreen. Where I would expect to see a non-centered, non-fitted, image, instead I see a non-fitted, but vertically centered image.
Once I page down to the next, the Reset X/Y seems to take effect and everything works as expected. I can even return to the previous with page up and then it looks okay.
Am I overlooking something? Is there a way to just completely disable centering, including for the first picture viewed? It doesn't make sense that I would want all pictures except the one I open first uncentered. I'd like to disable centering completely.
One alternative I noticed was that if Enter is changed to Browser > Viewer > Full screen or Browser > Fullscreen > Viewer, it works as expected. So I think it may be a bug that it happens for Browser <> Fullscreen | Viewer <> Full screen
And now to completely change the topic...
I like that XnView can work well with Total Commander. Is there any way to set it up so that if I start viewing images in XnView from TC, when I return to TC it will have the last viewed image selected. This would be the equivalent of the "Synchronize Browser selection with current View" option in XnView, only with TC instead of XnView's own browser. I understand that there is only so much you can do from your program though, so it may not be possible, but I thought I'd ask.
Thanks for your time!
