When load scanner with more than 2 documents, and use the Acquire Into feature, the first two documents get file names using the increment feature, but documents 3 through x get imported back into XnView as 'Scan 3', 'Scan 4', etc.
Using Acquire Into, File Type PDF, Start Index 1, 1 Digits, Even and Odd Pages, Format PDF, Save as Multi page is not checked
Thank you for a great app!
1.96.1 Acquire Into for more than 2 documents
thynnus
Re: 1.96.1 Acquire Into for more than 2 documents
Drat. How can I help run this down.xnview wrote:Sorry but i can't reproduce
The odd thing is that the index counter in the dialog is incremented for each document returned by scanner, even though documents 3 and up just show up as un-saved 'Scan 3' etc.
