RC3: View As and Sort By droplist missing!
ckit
Post by ckit »
Subject says it all :)
Re: XnView 1.80 RC1 - View As and Sort By droplist missing!
ckit wrote:Subject says it all :)
The "View as" and "Sort by" drop down lists have moved to the "small" toolbar, next to large drop downlist which shows the current directory.
ckit
Post by ckit »
Yes, I know they have been moved to the "small" toolbar but they still don't work.
ckit wrote:Yes, I know they have been moved to the "small" toolbar but they still don't work.
O.k. What's exactly happening?
Could you please
1 - Quit XnView
2 - Rename the xnview.ini
3 - Start XnView, again
and then see whether it works?
ckit
Post by ckit »
Ok, I was using the registry for my settings. I switched that off and went back to the INI file (deleted the old one first) and now the bug is gone.
So I assume if I delete the registry key, the same thing will happen as the INI file.
ckit wrote:Ok, I was using the registry for my settings. I switched that off and went back to the INI file (deleted the old one first) and now the bug is gone.
Do you have the old .ini used?
Dreamer
Post by Dreamer »
Yes, it causes the old .ini file, also another bug with a new Tab bar, it's ok after I removed it...
However a little bit annoying, to configure it all again - and now with a new RC1 again:
With old .ini from 1.80 beta I've got a blank grey full screen at start - every time...
Could you send me your old .ini file, please?
Dreamer
Post by Dreamer »
xnview wrote:Could you send me your old .ini file, please?
Sent.
Sent.
Ok, the problem is old toolbar.
Dreamer
Post by Dreamer »
Post by Lesmo16 / Moved
RC2: Empty ComboBoxes View as & Sort by
The ComboBoxes "View as" and "Sort by" in the small icon bar can be dropped down,
but both are empty (no entries visible).
I can select and activate these invisible entries, so the function is given.
xnView 1.80 RC2 on Win XPpro / SP2
Dreamer
Post by Dreamer »
It's a known bug with old .ini file.
Do this:
- close xnview
- rename xnview.ini to xnview.ini.bak
Hacker
Post by Hacker »
Dreamer,
No, it's not. It's caused by the option General - Startup - Use XP style menus.
HTH
Roman
Hacker
Post by Hacker »
Not fixed in RC3.
Roman
Dreamer
Post by Dreamer »
Hacker wrote:Dreamer,
Right.
Not fixed in RC3.
Roman
Right, but why it is here as "[OK]" ?
Could you explain Helmut/Pierre please?
Everyone can disable that option, but it's still a bug I think...
Therefore moved back to "New and Open Bugs, Requests, and Suggestions"
Locked
