Hiding .REG files
Hiding .REG files
When I activate Recognize only by extension, .REG files are displayed as blank thumbnails, even though Show items in view ‘Thumbnails’ is disabled for Text files.
  • Image
Re: Hiding .REG files
XnTriq wrote:When I activate Recognize only by extension, .REG files are displayed as blank thumbnails, even though Show items in view ‘Thumbnails’ is disabled for Text files.
I can't reproduce, do you have same thumbnail in windows explorer?
On my system Windows Explorer displays the file-type icon for REG files in thumbnail view:
As it turns out, some REG files are identified correctly by XnView v1.97 beta 3 (Filter By = All):
:? Does it depend on the filesize?
Could you send me a .reg?
Diplay all image file types and Ignore read errors have the same effect.
  • 4.reg = Exported with RegEdit to v4 format (ANSI)
  • 5.reg = Exported with RegEdit to v5 format (Unicode)
  • 5_ansi.reg = Exported with RegEdit to v5 format and coverted with Notepad from Unicode to ANSI
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.reg]
@="regfile"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.reg\PersistentHandler]
@="{5e941d80-bf96-11cd-b579-08002b30bfeb}"
Hmm, no problems with .reg files, here. (I've tried the settings mentioned above).
ckv
Post by ckv »
I can't reproduce this either.
XnTriq do you have reg extension set in the TxtExt setting?
Only way I could get thumbnails out of .reg files was to add reg files to that setting.
Thanks for testing, everyone! “Unsolved mysteries” are driving me nuts :P
ckv wrote:XnTriq do you have reg extension set in the TxtExt setting?
Good thinking! After adding the extension to the list...
TxtExt=txt c c++ cc h cpp pas js css php ini reg
... all .REG files disappear when Filter by is set to Custom.
Now, if I'm activating Show items in view ‘Thumbnails’ for Text files and rebuild the thumbs, this is what I get:
  • Image
