Use Of Wildcards
Lif3styl3
Use Of Wildcards
Post by Lif3styl3 »
I have problems using a wildcard, while filtering the input files.
i would like to filter the files which has got spaces in their path.
Regarding to the Dos Syntax i need to escape the path ("my dir").
so i tried something like "c:\my dir\sdf sd"*.png, but nconvert could not find the requested files.
Re: Use Of Wildcards
Lif3styl3 wrote:so i tried something like "c:\my dir\sdf sd"*.png, but nconvert could not find the requested files.
Yes this can't be expanded correctly...
Pavel Chysky
Post by Pavel Chysky »
Nconvert.exe knows wildcards, but without quotations only, or knows quotations, but without wildcards only:
c:\mydir\sdf sd*.png - OK
"c:\my dir\sdf sd.png" - OK
"c:\my dir\sdf sd".png - OK
"c:\my dir\sdf sd*.png" - failed
"c:\my dir\sdf s"d*.png - failed
It seems the only way to workaround for spaces in path is:
CD /D "c:\my dir" (or simply CD /D c:\my dir - CD has not space as separator)
but nconvert.exe -xxx sdf sd*.png still failed
Any suggestion for spaces in filename?
