XnView and metadata, how does it work?
Troken
Post by Troken »
I've usually worked with IPTC-metadata with my images, but I've learned that XMP might be better and with more advantages than IPTC (ie. more supported image formats). So can XMP replace IPTC? And what formats does XnView support for XMP?
Re: XnView and metadata, how does it work?
XnView works only on IPTC, but can create XMP from IPTC
XnViewMP works on IPTC or XMP
Troken
Post by Troken »
xnview wrote:XnView works only on IPTC, but can create XMP from IPTC
So if I edit metadata in IPTC, I can get a XMP copy of that data? (JPG & TIF?)
2nd question: Can XnView read/display XMP from other formats than JPG & TIF?
Troken wrote:So if I edit metadata in IPTC, I can get a XMP copy of that data? (JPG & TIF?)
Yes, if XMP is activated in IPTC dialog
XMP can be imported from JPEG/TIFF/PNG/PSD
