Xnview command line /print - two images on page?
Galkin
Post by Galkin »
Xnview 1.97.6 , Windows XP, User code LTD Pharmcomplect
Command line:
xnview.exe sample.tif /print
Exist additional key for print two images on one page?
Analogous main window Xnview : Print-Page Layout-Page Layout=Pictures Collection=5"x7"(127x178 mm)[2]=[V]Multiple images per page
May be use -ini <file> options? Then description of structures <file>?
Sorry, my english is very bad
Re: Xnview command line /print - two images on page?
No sorry, currently no way to do that...
Galkin
Post by Galkin »
Thanks.
Galkin
Post by Galkin »
xnview wrote:Please try XnView 1.98 beta 1
XnView 1.98 beta 2
D:\xnview\xnview.exe -ini D:\xnview\1.ini /print D:\add\1.tif
1.ini:
[Print]
AllPages=0
AutoRotate=0
BottomMargin=0.20
CType=0
Columns=2
EFontBold=0
EFontHeight=10
EFontItalic=0
EFontName=Courier
ETextColor=0
FText=Page <Page Number>/<Page Count>
First=1
FontBold=0
FontHeight=10
FontItalic=0
FontName=Arial
Gamma=1.00
HText=
Height=10.00
HoriSpacing=1.00
JobPerPage=0
KeepRatio=1
Last=1
LeftMargin=0.20
Multiple=1
Option=5
Position=4
RightMargin=0.20
Rows=2
Text=
TextColor=0
TextPosition=0
TextUse=1
TopMargin=0.20
Units=0
UseFooter=1
UseHeader=0
VertSpacing=1.00
WFontBold=0
WFontHeight=10
WFontItalic=0
WFontName=Courier
WFontOrientation=0
WOrientation=0
WText=
WTextColor=0
WTextPosition=0
WUse=0
Width=10.00
XScale=2.00
YScale=2.00
It work !!!
Testet in 3 computers - OK
Very big thanks!!!
Galkin
Post by Galkin »
XnView 1.98 beta 3
It work !!!
Very big thanks!!!
Sorry, we have some problem with command line in XnView.
When we use command like this
D:\XnView\xnview.exe -print \\Sertifikat\Sertif\r\tabel_841010.tif -ini D:\XnView\xnview2.ini
Xnviev works correctly.
But if we use symbol - "" (quotes) in key -print (for example -print "\\Sertifikat\Sertif\r\tabel_841010.tif"). XnView can't find file \\Sertifikat\Sertif\r\tabel_841010.tif.
So, command like this - D:\XnView\xnview.exe -print "\\Sertifikat\Sertif\r\tabel_841010.tif" -ini D:\XnView\xnview2.ini does not work.
We must use "" (quotes) because some our files have spaces in name(for example D:\tabel_1 0988.tif or D:\tabel12 8899.tif .etc).
How do we solve this problem?
Thanks in advance.
Galkin wrote: But if we use symbol - "" (quotes) in key -print (for example -print "\\Sertifikat\Sertif\r\tabel_841010.tif"). XnView can't find file \\Sertifikat\Sertif\r\tabel_841010.tif.
ok, i'll check
Galkin
Post by Galkin »
ok, i'll check
Very big thanks! On XnView 1.98 Release no problem.
Galkin
Post by Galkin »
Hello.
New problem.
We have some problem with command line in XnView.
We use XnView command line for printing files
(for example we use command like this D:\XnView\xnview.exe -print \\Sertifikat\Sertif\r\tabel_841010.tif -ini D:\XnView\xnview2.ini).
In Print Properties we set Page layout=Thumbnails, Columns=2, Rows=2 and trying to print.
If multipage file *.tif contains 1,2,3 or 5 pages XnViev works correctly, but if multipage file *.tif contains 4 pages, XnViev print empty sheet at the end of the print cycle.
When in Print Properties we set Page layout=Thumbnails, Columns=1, Rows=2 and trying to print. If multipage file *.tif contains 1,3 or 5 pages XnViev works correctly, but if multipage file *.tif contains 2 or 4 pages, XnViev print empty sheet at the end of the print cycle.
But if we use interface of XnView, it works correctly, regardless of the number of pages without empty sheets at the end of the print cycle .
Why XnView print empty list when we use command line? We can't find the reason for this. Help us please.
Could you send me the xnview2.ini & a tif file?
Galkin
Post by Galkin »
2.ini - Page layout=Picture collection 5"x7"(127x178 mm)(2)
4.ini -Page layout=Picture collection 3.5"x5"(89x127 mm)(4)
02.ini - Page layout=Thumbnails Columns=1 Rows=2
04.ini - Page layout=Thumbnails Columns=2 Rows=2
E01.tif - file for print
Each of these ini files (when we priny E01.tif) gives empty sheet at the end of the print cycle
http://depositfiles.com/files/4qppqozd3
ok, i found. If you want a test version, tell me
Galkin
Post by Galkin »
I am ready.
That it is necessary to do?
Galkin
Post by Galkin »
I am testing xnview (1.98.3 beta)
http://www.xnview.com/beta/xnviewb.zip
Command line
xnview.exe -print d:\xnview\01.tif -ini d:\xnview\xnview.ini
xnview.ini - It will not be involved, prints ONLY one image on sheet
Xnview 1.98.1 - work, but empty sheet
could you send me the xnview.ini?
