Slow performance on Win7 X64 - Large Files
How to use XnView Classic. Post your question or ask for help, here.
Postby ianc » Mon Jun 20, 2011 8:37 pm
Hi Folks,
I searched on 'X64 performance' but didn't turn up much, so here I go:
I've been running XNView for years with great results. Most recently I was running it on XP SP3 X86 on an Intel Core2 Duo with 2 GB of RAM and it was quite fast.
However, I've now upgraded to an i5 2500K with 8 GB of RAM and have Win7 SP1 X64 installed. The HD's are the same 3 GB/s SATA, and the display adapter is a 640 MB Geforce 8800 GTS (if that matters).
Performance with smaller pictures is still adequate, but I'm now seeing MUCH slower performance on larger images (~3400x3400) than before. It is taking about 2-3 sec each to load these images, which is really starting to get to me. These same images loaded very quickly (almost instantly) under X86 XP.
I was initially running 1.96, so updated to 1.98, but that didn't help matters I'm afraid. I do have thumbnail caching enabled, and thumbnail are quite fast; it is just the full image that is VERY slow to display...
Any suggestion to improve Performance? I didn't see an X64 version avaiable for download... Thanks for any help,
Ian
ianc
Re: Slow performance on Win7 X64 - Large Files
Postby xnview » Tue Jun 21, 2011 6:49 am
Same version on the 2 PC? Do you use option/Fullscreen>Use delayed high quality?
Postby ianc » Thu Jun 23, 2011 6:39 am
Yes, I was originally running 1.96 on the Core2 Duo machine, then used the same installation after upgrading to Win7 X64 by copying it. When I had trouble, I upgraded to 1.98 on the Win7 machine; but it didn't help.
Yes, this was enabled by default. I tried turning it off and on and changing the value to 4000 pixels, but it didn't help... I have also in the interim upgraded from the Geforce 8800 GTS to a GTX 460 1 GB, but that didn't help either...
Thanks for your help!
ianc
ianc
Postby xnview » Thu Jun 23, 2011 7:10 am
You have slow performance in view mode?
Postby ianc » Fri Jun 24, 2011 2:51 am
Yes, in the full-screen view mode. When I initially click on a large image in the browser, the delay is noticeable. The image loads, and when I use my mouse wheel to scroll to the next image in the folder, there is a 2-4 second delay before the image displays on the screen,
Ian
ianc
Postby xnview » Fri Jun 24, 2011 7:01 am
and View/Misc>Read ahead?
Postby ianc » Sat Jun 25, 2011 4:36 am
Under the cache selections, 'Read one image ahead', and 'Keep current image in cache' are both checked...
Ian
ianc
Postby xnview » Mon Jun 27, 2011 7:19 am
You can perhaps try to copy old ini on your new PC?
Postby ianc » Mon Jun 27, 2011 9:24 pm
I copied over the entire installation directory, including the .ini file... :(
Ian
ianc
Postby xnview » Tue Jun 28, 2011 6:54 am
If you use File>Open & next file, same problem?
Postby ianc » Fri Jul 01, 2011 5:48 am
Yep, it is the same 2-4 sec delay for the image to open as just scrolling in the full screen view...
Ian
ianc
Postby xnview » Fri Jul 01, 2011 6:58 am
ianc wrote: as just scrolling in the full screen view...
What do you means?
Postby pic_viewer » Sat Jul 02, 2011 5:14 am
Anti virus scanner?
pic_viewer
Postby ianc » Sun Jul 03, 2011 4:07 am
What do you means?
I mean that if I double click on an image to view it full screen then scroll the mouse wheel to view the next image, I see the same 2-4 second delay as if I use File|open to select and view an image. Isn't that what you were asking? If not, please clarify...
Anti virus scanner?
I'm not running one. I have the default Windows Defender included with Win7 installed, but that's it...
Ian
ianc
Postby xnview » Mon Jul 04, 2011 7:34 am
Is it jpeg files?
Next
Return to General Support
Who is online
Users browsing this forum: No registered users and 3 guests
