Custom button with assigned batch processing "macro"
I_go_r
Post by I_go_r »
Hello.
It's often while browsing photos to need make same predefined transform for some of them (for example: Sharpen+Resize+Autobalance etc).
It will be very suitable to assign batchprocessing sequence to the button on main toolbar. Then while browsing photos it will be easy by one click to transform current photo by applying predefined batch proccessing conversion just by clicking button on toolbar.
Dreamer
Re: Custom button with assigned batch processing "macro"
Post by Dreamer »
Good idea, there is something similar in FreeCommander for Multi-Rename, the main button and [v] sub-button with the list of "profiles".
I support this idea and add the same for batch rename - in browser.
Dreamer
