XnView MP 0.38.10: crash when adding new files to a folder
Fraenzken
Post by Fraenzken »
When I open a folder containing RAW files with XnView MP, open one of the files via the "open with" feature in the raw converter Bibble and let Bibble write a jpg to the same folder, XnView MP crashes - not always, but quite often.
Cheers, and keep up your brillant work!
Frank
Re: XnView MP 0.38.10: crash when adding new files to a fold
Same problem if you don't use 'open with'?
With Bibble, you use 'save as'?
