Problem - spaces and wildcards in parameters
lzoch1
Post by lzoch1 »
Hello, is there any solution for this problem ?
Nconvert.exe knows wildcards, but without quotations only, or knows quotations, but without wildcards only.
Is any possibility how to correctly use this command?
nconvert.exe [other parameters] -o c:\destination dir\%.jpg c:\source dir\*.jpg
where "c:\destination dir" and "c:\source dir" are real names of directories (with spaces). In destination dir can be used underscores (_) instead of spaces, but source dir can be on CD - any renaming as not possible.
Re: Problem - spaces and wildcards in parameters
Do you have tried:
nconvert.exe [other parameters] -o c:\destination dir\%.jpg c:\source^ dir\*.jpg
lzoch1
Post by lzoch1 »
xnview wrote:Do you have tried:
Sorry, it doesn't work. I will describe my situation:
Directory structure:
C:.
| +---destination dir
Using CONVERT.BAT file which include:
Nconvert.exe -ratio -rflag orient -resize 640 480 -rtype lanczos -out jpeg -q 75 -o c:\!!\destination dir\%.jpg c:\!!\source^ dir\*.jpg
This is output from BAT file(error):
c:\!!>convert.bat
c:\!!>Nconvert.exe -ratio -rflag orient -resize 640 480 -rtype lanczos -out jpeg -q 75 -o c:\!!\destination dir\\!!\source dir\*.jpg
** NCONVERT v5.75 (c) 1991-2010 Pierre-E Gougelet (Sep 7 2010/11:24:20) **
Version for Windows NT/9x/2000/Xp/Vista/7 (All rights reserved)
** This is a freeware software (for non commercial use)
Error: Can't open file (dir\\!!\source)
Error: Can't open file (dir\*.jpg)
c:\!!>
Can you help me, what is wrong?
Many thanks!
Ladislav
Ok, so here the only way is to use a bat command + for
lzoch1
Post by lzoch1 »
xnview wrote:Ok, so here the only way is to use a bat command + for
Thank you, the best way will be using XNconvert, there are no problems with spaces, diacritics and so on in directory- and file-names.
Ladislav
