0.39 Win-x64 Can not drag and drop
CreativeWorld
Post by CreativeWorld »
So, as of this new build (not keep up with it) but I can no longer just "drag & drop" my images from one folder to an other. All images are with in a one main image folder and then broken up into cats. Is their anyway to get "drag and drop" to work again. Please fix it in next release as this is a pain to manage images having to select them and then use the move to comment.
Re: 0.39 Win-x64 Can not drag and drop
you means you can't drag&drop files from thumbnail view into a folder in thumbnail view??
CreativeWorld
no, I mean from thumbnail to tree view (folders). Image preview is below. You can do this kind of drag and drop using the stable build (XnView).
http://i.imgur.com/NL8jM.jpg
right, not yet implemented...
CreativeWorld
Ah ok, thanks for letting me know. Thought it was a bug.
