RC6: Multiple Files Delete crash
1. Open XnView in Browser mode
2. Switch to ANY "View As" mode
3. Select multiple files (I used 7 files) and Press Shift+Del -> Yes
4. Crash with Dr Watson log created and XnView is closed.
I didn't stop pressing Shift until the crash message appeared not sure if thats important or not.
Please try again...
3. Select multiple files (I used 7 files) and Press Shift+Del -> Yes (keep pressing "Shift" as you press Enter for Yes)
Don't stop pressing Shift until XnView crashes with a error message.
If I stop pressing Shift at the "Are you sure" dialog there is no crash.
This also happens if you use the delete function on the right-click menu with Shift as well.
Ok I found the problem and fixed it, please delete this whole thread.
There was a FLC clip in the same folder that was causing the problems all a long!
XnView doesn't handle FLC files well at all. Copy Helmut's FLC sample file (http://www.sfp-online.de/xnview/web/temp/matein5.flc) into a folder with some other files and test for my bug.
I don't think it's a bug, as long as Pierre can fix the bug in Helmut's post about a FLC bug - http://newsgroup.xnview.com/viewtopic.php?t=2458 this should go away.
