Crash When copy to clipboard
Flandre Scarlet
Post by Flandre Scarlet »
When i use the 0.39 version , The copy command is not work.
I'm open an image and make a selection and copy it.
but it will copy the All image , I just want to Copy the selection.
So i test the new version 0.49beta(May 17 2012)
I do the same things
But it's not work ..and ...Crash!
i think this is a Bug.
PS. Open the XnViewMP and goto the windows explorer to copy something like some files or some text
the XnViewMP will Crash. So i think maybe some problems to read Clipboard .
(Win7 X64)
Flandre Scarlet
Re: Crash When copy to clipboard
I Made some tests
it is not Crash now, But still not work.
make a selection and copy.
Only .png file is work. Jpg or Gif or other image format is not work .
jpg or gif file will copy all the image not the selection.
But the "Copy to clipboard" -> "Image data" (Ctrl + Shift + C) looks like work.
The Copy command (Ctrl + C) just worked on png file With a selection.
Flandre Scarlet wrote: make a selection and copy.
Selection of files in the xnview browser?
And you paste where?
Flandre Scarlet
Like This !
i just want to copy the eyes
and paste to photoshop or other where.
but Ctrl+C will copy the entire image not the selection
png file will work
jpg not work
Flandre Scarlet wrote: but Ctrl+C will copy the entire image not the selection
png file will work
jpg not work
It works for me, and strange, the code is the same for all file format...
budz45
Post by budz45 »
Perhaps a compatibility issue with another XnViewMP setting is causing this issue
Florian, try doing your selections with a 'clean' xnview.ini file and then report if you have the same problem.
Flandre Scarlet
I Clean the XnView.ini
But still not work.
ok, photoshop is work fine.. just not work for my IM software...
But some format is work perfect. and Ctrl+Shift+C is work for all format.
The Ctrl+C and Ctrl+Shift+C has same code ? It is strange...
and Xnview does not have this problem. Just Mp have
and XnviewMP is used Unicode?
I see some Asian Character is transform to \x00xx in Xnview.ini
for example:
PathBrowser=C:/Users/Flandre Scarlet/\x30de\x30a4 \x30d4\x30af\x30c1\x30e3/
This is normal ?
And thank you for your attention.
Flandre Scarlet wrote: But some format is work perfect. and Ctrl+Shift+C is work for all format.
It works with Ctrl+C and not with Ctrl+Shift+C??
for example:
This is normal ?
Yes i think
Flandre Scarlet
xnview wrote: It works with Ctrl+C and not with Ctrl+Shift+C??
Ctrl+Shift+C is Work.
Ctrl+C just work for some Format.
i tested PSD, Png, tif is work to copy the selection.
Jpg, Gif, Bmp will copy the entire image not selection.
Tga, dds, iff copy nothing.
Ctrl+C: Copy image data rect + filename
Ctrl+Shift+C: Copy only image data rect
So i think that some software don't use image data but filename
