Windows Explorer thumbs.db
soulky
Post by soulky »
Why does xnviemp not use the Windows Explorer thumbs.db? For users who switch from Windows Explorer to xnviemp, it would be great time saving, if xnviewmp would import already existing thumbnails from the thumbs.db instead of recreating them.
Re: Windows Explorer thumbs.db
Currently i don't know how to read it
JohnFredC
Post by JohnFredC »
A Google search "how to read thumbs.db" turned up many hits with links to code: C++, C#, Delphi, even Visual Basic.
I haven't tested any of them, but the following is cited frequently:
A C++ approach
John
budz45
Post by budz45 »
It would be really great if XnView software had this ability. I support +1 :)
obelisk
Post by obelisk »
thumbs.db doesn't exist in win7
Moderator & Librarian
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=80738#p80738]Thumbs.db and explorer addon[/url]) wrote:
  • MiTeC: Windows File Analyzer » Thumbnail Database Analyzer
    This analyzer reads Thumbs.db file and displays its content with stored data include image preview.
  • IT Samples
    • Thumbnail Database Viewer
      Thumbnail Database Viewer enables you to view thumbnail cache which is used by Windows to speed up the display of thumbnails in folders (thumbs.db. ehthumbs.db, thumbcache_*.db files).
    • Thumbnail Database Cleaner
      Thumbnail Database Cleaner enables you to clean up thumbnail cache which is used by Windows to speed up the display of thumbnails in folders (thumbs.db, ehthumbs.db, thumbcache_*.db files). Usually these files are system files and hidden.
  • Wikipedia: Windows thumbnail cache
  • Mr.XRAY: 792_ExplThumbnail » #05
