I love that TreeView control
Rebellious
Post by Rebellious »
Very meticulously crafted control. They don’t write software like this anymore. Congratulations! :)
Only one suggestion: I’m using mid-tone background, so the dotted lines become invisible, should be black or inverse.
Re: I love that TreeView control
Add these lines to style_sheet.qss
QTreeView::branch:has-siblings:!adjoins-item {
border-image: url("UI:branch_vline.gif") 0;
QTreeView::branch:has-siblings:adjoins-item {
border-image: url("UI:branch_more.gif") 0;
QTreeView::branch:has-children:!has-siblings:closed,
QTreeView::branch:closed:has-children:has-siblings {
border-image: none;
image: url("UI:branch_closed.gif");
QTreeView::branch:open:has-children:!has-siblings,
QTreeView::branch:open:has-children:has-siblings {
border-image: none;
image: url("UI:branch_open.gif");
QTreeView::branch:!has-children:!has-siblings:adjoins-item {
border-image: url("UI:branch_end.gif") 0;
… and place the following files in the UI subdirectory of your XnView MP installation:
Foreground color: #603024 = R96/G48/B36
Background color: #9fcfdb = R159/G207/B219
On second thought: Just adding this “code”…
QTreeView::item {
color: rgb(0, 0, 0);
QTreeView::item:hover,
QTreeView::item:selected:active,
QTreeView::item:selected:!active {
color: rgb(255, 255, 255);
… to style_sheet.qss will also do the trick (without the need for any extra images) :mrgreen:
Rebellious
Thank you, There is style_sheet.qss & style_sheet_linux.qss, the first one has the the following, the 2nd is empty file.
Are these values hardcoded at design time OR dynamically modified by the app at runtime?
QTreeView::item{
    color: rgb(220,220,220);
    border: 0px solid green;
QTreeView::item:alternate{
QTreeView::item:selected:!active{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(80, 80, 80), stop:1 rgb(70, 70, 70));
QTreeView::item:selected:active{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(80, 80, 80), stop:1 rgb(60, 60, 60));
QTreeView::item:hover{
Hi Rebellious
Rebellious wrote:Are these values hardcoded at design time OR dynamically modified by the app at runtime?
I'm a Windows user, but I assume that things are handled not too differently on Linux:
  • %ProgramFiles%\XnViewMP\UI\ = installation (static)
    1. style_sheet.qss
    2. style_sheet_linux.qss
    3. style_sheet_mac.qss
    4. style_sheet_win.qss
  • %AppData%\XnViewMP\ = configuration (dynamic / per user)
    1. style_sheet.qss
    2. style_sheet_win.qss or
You can edit the config files either manually (text editor) or inside XnViewMP:
  • View » Theme » Dark theme
Rebellious
Thank you. It didn’t work. I got some very ugly colors all over the app not just the treeview. I had to delete style_sheet.qss in the user dir to get back to default colors. You need some code to set treeview dotted lines color to inverse of background color.
Rebellious wrote:I got some very ugly colors all over the app not just the treeview.
Could you post a screenshot?
What distro (Arch Linux, openSUSE, …) are you on?
Do you use the Cleanlooks theme?
Is the treeview's background turquoise by default on your system?
OK, I'm afraid this a wee bit too complicated for a Linux illiterate :P
Rebellious
Sorry for my delayed response...
As I mentioned above I deleted style_sheet and went back to default, so ugly colors are no longer there but it should be easy to reproduce.
Linux Mint MATE versions 13 & 14
YEs.
No, it's part of my selections for system-wide fonts & colors, and xnview ignores these in some cases.
Schattenreiter
Post by Schattenreiter »
looking superb :)
HackIntosh
Mountain Lion 10.8.2G530GA-Z77M-D3HSapphire 5770Soundblaster Audigy Platinum16GB-1333-DDR3Atheros AR9280
